OpenFOAM: something wrong with my compiler?
Old   June 1, 2012, 13:38
Unhappy OpenFOAM: something wrong with my compiler?
S.J.Daniels is on a distinguished road
Hi there,
I've recently installed swak4Foam with OpenFOAM 1.7.1.
It seems to have compiled successfully. However when I run one of the tutorials with in swak4Foam (in this case the pulsedPitzDaily case in groovyBC) I get the following feedback.
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model oneEqEddy
--> FOAM Warning :
From function cubeRootVolDelta::calcDelta()
in file cubeRootVolDelta/cubeRootVolDelta.C at line 52
Case is 2D, LES is not strictly applicable
oneEqEddyCoeffs
ck 0.07;
ce 1.05;
Starting time loop
DICPCG: Solving for distance, Initial residual = 1, Final residual = 9.97476e-07, No Iterations 227
DICPCG: Solving for distance, Initial residual = 5.26588e-09, Final residual = 5.26588e-09, No Iterations 0
--> FOAM Warning :
From function dlLibraryTable:pen(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr)
in file lnInclude/dlLibraryTableTemplates.C at line 67
library "libsampling.so" did not introduce any new entries
Reading/calculating field UMean
Reading/calculating field pMean
Reading/calculating field UPrime2Mean
Reading/calculating field pPrime2Mean
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::tmp<Foam::GeometricField<Foam:uterProduct< double, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::sqr<double, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#4 void Foam::fieldAverage::addPrime2MeanField<double, double>(int, Foam::List<Foam::word> const&, Foam::List<Foam::word>&) const in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#5 Foam::fieldAverage::initialize() in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#6 Foam::fieldAverage::read(Foam::dictionary const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#7 Foam::fieldAverage::fieldAverage(Foam::word const&, Foam:bjectRegistry const&, Foam::dictionary const&, bool) in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#8 Foam::OutputFilterFunctionObject<Foam::fieldAverag e>::allocateFilter() in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#9 Foam::OutputFilterFunctionObject<Foam::fieldAverag e>::start() in "/opt/openfoam171/lib/linux64GccDPOpt/libfieldFunctionObjects.so"
#10 Foam::functionObjectList::read() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#11 Foam::Time:perator++() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#12 Foam::Time::loop() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#13
in "/opt/openfoam171/applications/bin/linux64GccDPOpt/pisoFoam"
#14 __libc_start_main in "/lib/libc.so.6"
#15
Floating point exception
I found this a bit strange, I also have two other bits of code I'm using for a project. These were working before I installed swak4FOAM but now they get a similar error message.
Can someone tell me what's going on, or help with a solution?
Best Regards,
Steven
S.J.Daniels is offline   Reply With Quote
Old   June 1, 2012, 13:43
Retired Super Moderator
Bruno Santos
Greetings Steven and welcome to the forum!
OK, you didn't mention the Gcc version, although you blamed it
A few questions:
  • What Gcc version are you using?
  • What Linux distribution and version are you using?
  • Which swak4Foam version are you using?
There's a compatibility matrix showing the relation between OpenFOAM and Gcc versions: http://openfoamwiki.net/index.php/In...ibility_Matrix
Best regards,
Bruno
Old   June 1, 2012, 14:30
Hi Bruno,
Many thanks for your quick response! In answer to your questions:
gcc version 4.4.5 - according to the matrix it seems to be compatable with OF1.7.1.
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=10.10
DISTRIB_CODENAME=maverick
DISTRIB_DESCRIPTION="Ubuntu 10.10
I don't know what version of swak4Foam I've downloaded, but I downloaded it from this website: http://openfoamwiki.net/index.php/Contrib/swak4Foam
I used the command from the following section:
The current version that works with 1.x-releases of OpenFOAM can be downloaded using the following command..
Thank you for your time,
Steven
Old   June 2, 2012, 08:38
Bruno Santos
Hi Steven,
OK, first thing, we need bash as the default sh (the default in Ubuntu is dash):
sudo update-alternatives --install /bin/sh sh /bin/dash 1
sudo update-alternatives --install /bin/sh sh /bin/bash 1
sudo update-alternatives --config sh
Then pick "0".
Then install bison:
sudo apt-get install bison
If you want python integration as well, see the file "swakConfiguration.example" and copy-edit to "swakConfiguration".
Then build swak4Foam:
./Allwmake
If you still have problems, run it again like this:
./Allwmake > make.log 2>&1
tar -czf make.log.tar.gz make.log
Then attach "make.log.tar.gz" to your next post.
Best regards,
Bruno
Old   June 3, 2012, 05:40
Assistant Moderator
Bernhard Gschaider
The actual error you posted happens in a library that comes with OF so my lawyer told me do deny all responsibility
Anyway: the only way I can see swak being involved here is that the groovyBC wrote for instance a NaN and that lead to the floating point exception in another library (which is what you're seeing)
Starting with the latest release the utilities that come with swak4Foam (for instance funkySetFields) give a swak-version-number. If you're not seeing that then you don't have the latest release.
Old   June 3, 2012, 16:41
Bruno Santos
Greetings to all!
After Bernhard's post, I remembered that I forgot to check if the tutorial worked for me. I tested the tutorial "Examples/groovyBC/pulsedPitzDaily" by running:
blockMesh
pisoFoam
And It ran with no problems till 0.00037s, which was when I canceled execution, since the initial report indicated that it would crash at the first time step.
Best regards,
Bruno
Old   June 10, 2012, 09:46
Hi Everyone!
Many thanks for your advice and suggestions. I've got swak4Foam working now!
Best Regards,
Steven
Old   June 10, 2012, 15:59
Assistant Moderator
Bernhard Gschaider
If any of the suggestions here was the right one OR if the problem was something different, could you just write one sentence about that here? Not for me but the next poor soul who has the same problem as you and finds this thread via the search-function of the MessageBoard
Old   June 11, 2012, 11:13
Hello all,
Swak4Foam worked after I followed Bruno's instructions earlier in this thread (installing Bison etc.). I haven't tried the Python integration yet.
Thanks again,
Steven
Old   June 13, 2012, 17:45
Assistant Moderator
Bernhard Gschaider
Hello all,
Thanks again,
Steven
Thanks for the clarification.
Python integration has potential. But don't spend too much time on it if you don't need it
udf error srihari FLUENT 1 October 31, 2016 14:18
OpenFOAM 1.7.x using intel compiler and MVAPICH2 kpsl OpenFOAM Installation 8 August 12, 2011 13:44
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM compiled with Intel C++ Compiler? af631717 OpenFOAM Running, Solving & CFD 4 June 5, 2009 06:41
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
