September 15, 2022, 09:11 |
High resolution block within a block mesh
Joost Linthorst
Rep Power: 5 |
Hey all,
So I need to have a high resolution zone inside a larger area. I have tried many different methods and have finally arrived to a method that works, but I'm getting a lot of mesh errors and warnings. I was wondering if anyone has a good method for creating this type of high resolution zone within a block mesh. My current approach is to create multiple blocks and use mergePatchPairs to "glue" them together. I have also used refineMesh, but refineMesh only doubles the resolution and I would like to have an even higher resolution zone than double the resolution. Thanks in advance, my blockMesh is attached. Last edited by JoostLinthorst; September 15, 2022 at 09:14. Reason: BlockMeshDict didn't attach |
September 15, 2022, 09:40 |
SnappyHexMesh
Joost Linthorst
Rep Power: 5 |
Using snappyHexMesh's refinementBox works like a charm.
blockmesh, refine mesh, resolution |
A high order curvilinear mesh generation(converting) tool is strongly recommended | hyperman | Main CFD Forum | 2 | August 7, 2018 17:30 |
A high order curvilinear mesh generation(converting) tool is strongly recommended! | hyperman | Mesh Generation & Pre-Processing | 0 | June 22, 2018 08:04 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh Resolution to resolve turbulent boundary layer | tongx051 | FLUENT | 1 | October 22, 2013 00:18 |
high mesh resolution causing vortex pimpleFoam | mvoss | OpenFOAM Running, Solving & CFD | 2 | March 8, 2012 07:06 |
