FSI solver
Like Tree3Likes
Old   June 18, 2012, 06:47
Default FSI solver
Nima Samkhaniani
nimasam is on a distinguished road
Hi dear foamers
im going to simulate a non-Newtonian flow with flexible pipe.
it would be a fluid solid interaction (FSI)
which solver is suitable?
any hint or guideline ?
nimasam is offline   Reply With Quote
Old   June 18, 2012, 07:33
Bernhard
Bernhard is on a distinguished road
Maybe fsiFoam of OpenFOAM 1.6-extend?
Bernhard is offline   Reply With Quote
Old   June 18, 2012, 08:51
Elvis
elvis will become famous soon enough
I agree with Berhard http://openfoam-extend.git.sourcefor...alysis;hb=HEAD
http://powerlab.fsb.hr/ped/kturbo/Op...Zagreb2007.pdf
outdated (OF1.2) FSI presentation & newtonian only (just for completeness).
http://www.openfoamworkshop.org/08/p...V_Kanyanta.pdf
a good read is 6th OF workshop =>Block-coupled solvers, I. Clifford, PSU
=>Multi-Zonal Multi-Physics Modeling: FSI and Congjugate Heat/Mass Transfer,R. Campbell and B. Craven, PSU
Fluid-Structure Interaction on sail fabric type structures Daniele Trimarchi (University of Southampton)
Numerical simulation of sailing boats dynamics FSI and shape optimization Manifolds Matteo Lombardi (École Polytechnique Fédérale de Lausanne)
there will be more FSI stuff on the 7th OF workshop so watch that presentations in a couple of weeks when they are online
nimasam likes this.
elvis is offline   Reply With Quote
Old   June 18, 2012, 14:07
Nima Samkhaniani
Hi again
i installed OpenFOAM 1.6-ext through debain pack,
in debain pack there is no example for icoFsiFoam.
and i could not launch to git "it gave me time out error connection"
However could you please put the solver example here
Old   June 18, 2012, 15:20
Elvis
how is your .bashrc for your debian installation of OpenFOAM 1.6-ext looking like?
My first impression is that this might be the cause of your trouble.
source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc
export FOAM_TUTORIALS=/usr/share/doc/openfoam-1.6-ext/examples
... etc. This debian installation follows the debian guidelines and differs to OF habits
Old   June 18, 2012, 15:23
Nima Samkhaniani
thanks for your reply, i found the example files in usr/share/doc but it dose not have any example for icoFsiFoam
Old   June 18, 2012, 16:03
Elvis
the tutorial case is http://openfoam-extend.git.sourcefor...eSmall;hb=HEAD
the solver is http://openfoam-extend.git.sourcefor...siFoam;hb=HEAD
or short cut sol cd stressAnalysis/icoFsiFoam to the sources.
I looked into 5th OF workshop installation and path there was
/usr/share/doc/openfoam-1.6-ext-dbg/examples/stressAnalysis/icoFsiFoam/flappingConsoleSmall to the "tutorial case example" consisting solid and fluid in seperate directories
hope that helps
Old   June 21, 2012, 01:24
Nima Samkhaniani
as i said before, i found icoFsiFoam, but it does not have any example or tutorial case with it self: not in debain pack installation (http://openfoamwiki.net/index.php/Installation) not in kubuntu.iso from workshop (http://sourceforge.net/projects/openfoam-extend/)
and
i can not get OpenFOAM-extended from git with following command:
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM®-1.6-ext
because i face the following error:
openfoam-extend.git.sourceforge.net[0: 216.34.181.91]: errno=Connection timed out
fatal: unable to connect a socket (Connection timed out)
however, thats why i asked, please put the test case here
Old   June 23, 2012, 14:02
Retired Super Moderator
Bruno Santos
Greetings to all!
@Nima: check the front-page of the Extend-Project: http://www.extend-project.de/ - you'll find that the correct git clone command is this:
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/openfoam-extend OpenFOAM-1.6-ext
Best regards,
Bruno
Old   June 23, 2012, 14:17
Nima Samkhaniani
same error even with your command
Old   June 23, 2012, 14:42
Bruno Santos
Hi Nima,
Then try these, where the second should work even behind a firewall:
git clone git://repo.or.cz/OpenFOAM-1.6-ext.git
git clone http://repo.or.cz/r/OpenFOAM-1.6-ext.git
FYI: these are mirrors of the main Extend-Project repository.
Best regards,
Bruno
Old   September 7, 2016, 01:05
Default Error while unzipping
  #12
Viraj Belekar
viraj20feb is on a distinguished road
Greetings,
I am trying to install the files required for FSI in foam-extend-3.1 and I am following the steps on this site: https://openfoamwiki.net/index.php/E...tutorial_cases
But when I give this command:
tar -xzf Fsi_31.tar.gz
There is an error stating:
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Can anyone help?
Thank you
viraj20feb is offline   Reply With Quote
Old   September 7, 2016, 14:14
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by viraj20feb View Post
Greetings,
Can anyone help?
Thank you
Hi Viraj,
You should be able to find the FSI code in the foam-extend-3.1/extend-bazaar directory; run the ./Allwmake script in the extend-bazaar directory to download and compile the code.
Philip
bigphil is offline   Reply With Quote
Old   September 8, 2016, 01:56
Viraj Belekar
Originally Posted by bigphil View Post
Hi Viraj,
Philip
Hello Mr. Philip,
When I try to run the ./Allwmake script, I get the following error(Please refer attached).
Can you please help?
Thanks
Old   September 8, 2016, 10:09
bigphil's Avatar
Philip Cardiff
Hello Mr. Philip,
Thanks
Did you try run the "./Allwclean" script first and then run the "./Allwmake" script?
Also note that you need to be connected to the internet as the Allwmake script downloads the files.
If it is still failing, could you upload the entire text output of the Allwmake script here?
Philip
Old   September 9, 2016, 01:20
Viraj Belekar
Philip
I tried running the Allwclean script followed by Allwmake script and I tried to make a log file for both. But what I see is the log file remains empty while the output in the terminal window is a continuous never-ending error. You can see the attached images(one is the output for Allwclean and another is for Allwmake script). I have attached both the scripts as well.
Thanks a lot
Viraj
File Type: gz Allw-files.tar.gz (580 Bytes, 1 views)
Old   September 11, 2016, 11:23
Bruno Santos
Greetings to all!
@viraj20feb:
The problem is that your connection to the Internet is using another intermediate server to download the necessary files and instead of providing the correct file, it's providing some weird file.
Please follow these steps:
  1. Use the Internet Browser to visit the section "Installation" on this wiki page: https://openfoamwiki.net/index.php/E...n#Installation
  2. Find this block of text:
    First publicly available snapshot of the source code
    Is available here on the wiki, which was designed to work with ... Fsi_31.tar.gz
  3. Click on the link that is on the name "Fsi_31.tar.gz".
  4. It should now download a file that has 472 KB.
  5. Place the downloaded file inside the user folder. The user folder is indicated by the following command:
    echo $WM_PROJECT_USER_DIR
  6. Now go to the command line and run:
    cd $WM_PROJECT_USER_DIR
    cd FluidStructureInteraction/src/fluidStructureInteraction/stressModels/constitutiveModel
    pwd
    The last command will tell you the full path to the folder where you need to place the next two files.
  7. Now, on your Internet Browser, click on this link: https://github.com/wyldckat/FluidStr...titutiveModel/
  8. Click on the two files that are shown there (one at a time), namely on "constitutiveModel.C" and "constitutiveModel.H". For each file:
    1. it will show a new page with the contents of the file;
    2. right-click on the button that says "RAW" and save the linked file to the folder pointed out by the previous command from step #6
  9. Go back to the command line and run:
    cd ../../..
    ./Allwmake
Hopefully this will solve the problem.
@bigphil:
Sorry to say that doesn't work, due to later changes made to foam-extend 3.1 that broke the building mechanism for the extend-bazaar contributions. That's why I wrote the instructions given here: https://openfoamwiki.net/index.php/E...oam-extend_3.1
Best regards,
Bruno
Old   September 12, 2016, 02:42
Viraj Belekar
Originally Posted by wyldckat View Post
Greetings to all!
@viraj20feb:
    pwd
    cd ../../..
    ./Allwmake
@bigphil:
Best regards,
Bruno
Hi Mr. Bruno,
Thank you so much for your help. The problem is solved now
Old   September 12, 2016, 08:35
Viraj Belekar
Greetings to all!
@viraj20feb:
    pwd
    cd ../../..
    ./Allwmake
@bigphil:
Best regards,
Bruno
Hi Mr. Bruno,
I think the compilation was not completely successful. When I tried to run the 3Dpipe tutorial for fsiFoam solver, I get the following output:
./Allrun: 55: ./Allrun: fsiFoam: not found
I have also attached the output of ./Allwmake script. Please have a look.
Thank you
Last edited by viraj20feb; September 12, 2016 at 08:37. Reason: attachment forgotten
Old   September 13, 2016, 15:52
Bruno Santos
Quick answer: Please run the following commands:
./Allwmake > log.make 2>&1
gzip < log.make > log.make.gz
Then please attach the file "log.make.gz" to your next post. I ask this because the PDF file did not have any clear indication of any problem at all.
flexible pipe, fsi
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 08:23
error in two way fsi kmgraju CFX 1 May 2, 2011 02:32
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
FSI Negative Element Volume Fatal Error Aaron CFX 2 July 1, 2008 20:48
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
