2D mesh from netgen to OpenFOam
Old   May 14, 2012, 13:17
Default 2D mesh from netgen to OpenFOam
yu
xiyuqiu is on a distinguished road
Hello all,
I have created a 2D backward facing step flow and meshed it in netgen. However, when I try to do the
netgenNeutralToFoam filename conversion, openFoam abort the process and give me fatal error.
--> FOAM FATAL ERROR:
face 0 in patch 1 does not have neighbour cell face: 3(2023 0 8)
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 124.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/share/apps/of/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/share/apps/of/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const in "/share/apps/of/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/share/apps/of/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 main in "/share/apps/of/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/netgenNeutralToFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 __gxx_personality_v0 in "/share/apps/of/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/netgenNeutralToFoam"
Aborted
Anyone know why?
thanks so much
xiyuqiu is offline   Reply With Quote
Old   June 18, 2012, 12:20
Default same kind of error
Julien
Djub is on a distinguished road
I have the same kind of error:
face 0 in patch 0 does not have neighbour cell face: 4(1 5 6 2)
Nevertheless, my code is so simple it shouldn't have any problem!
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
// convertToMeters 1;
vertices
 (-4 -2 0) (10 -2 0) (10 2 0) (-4 2 0)
 (-4 -2 4) (10 -2 4) (10 2 4) (-4 2 4)
blocks
    hex (0 1 2 3 5 6 7) (100 30 30) simpleGrading (.5 1 1)
edges
boundary
    flux_entrant {
 type patch;
        faces ( (0 4 7 3) )   ; // pointe à l'exterieur du domaine
    flux_sortant {
 type patch;
        faces ( (1 2 6 5) )   ;
    les_parois {
 type symmetryPlane ;
 faces (
       (0 1 5 4)
       (4 5 6 7)
       (7 6 2 0)
       (3 2 1 0) );
mergePatchPairs
Could anybody help me?
Djub is offline   Reply With Quote
Old   June 18, 2012, 13:32
yu
Hi, I have found out netgen will not create a 2D geometry. If you want 2D case, you should use block mesh. This is how I get around the problem. hope this helps.
Originally Posted by Djub View Post
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
vertices
blocks
edges
boundary
    flux_entrant {
 type patch;
    flux_sortant {
 type patch;
    les_parois {
 faces (
       (0 1 5 4)
       (4 5 6 7)
       (7 6 2 0)
       (3 2 1 0) );
mergePatchPairs
Old   June 19, 2012, 02:02
Disabled
anon_a is on a distinguished road
hex (0 1 2 3 4 5 6 7)
Also:
(7 6 2 3)
anon_a is offline   Reply With Quote
Old   June 19, 2012, 04:15
Red face Thanks
Julien
so sully...
place setting of shame...
Of course, it works now.
I will try not annoying you anymore for that stupid mistakes...
Old   June 19, 2012, 11:02
Disabled
No problem, blockMesh is a little hard to master because you don't see what you are doing.
What about switching to another program?
For example, you can try SALOME, enGrid, gmsh...
Just take a look around the forum.
Old   June 19, 2012, 11:45
Default discretizer
Julien
A colleague of mine adviced me on discretizer (http://www.discretizer.org/).
By the way, I have allready so much to learn about OF, I prefer to concentrate on it and not get involved in different software (I also have to learn Linux-Suse, paraFoam,...).
'nice eveaning,
Julien
[Salome] mesh conversion Salome --> OpenFoam vaina74 OpenFOAM Meshing & Mesh Conversion 42 March 4, 2022 20:41
[Other] OpenFoam Mesh to Fluent Mesh, 2D lordvon ANSYS Meshing & Geometry 1 January 14, 2022 12:20
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
[Netgen] Geometry > Netgen > OpenFOAM ericnutsch OpenFOAM Meshing & Mesh Conversion 9 February 22, 2010 07:39
