July 23, 2012, 18:03 |
Natural Convection with icoFoam
Rep Power: 13 |
Hey Foamers
I have added energy equation to icoFoam, and I am solving natural convection in cavity. The problem is that as I am using smaller and smaller time steps, the velocities become smaller and smaller, and I can not get a results which is independent of time step. So do you have any ideas to help me getting time step independent results? |
July 24, 2012, 05:23 |
A_R
Rep Power: 16 |
dear mahdi
do you add temperature truly? it seams that your solver has a problem. you should attach your solver. it is hard to make decision without looking to your solver |
July 24, 2012, 11:43 |
Rep Power: 13 |
Dear Niyaz
this is my solver /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 1991-2010 OpenCFD Ltd. \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application icoFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #include "setRootCase.H" #include "createTime.H" #include "createMesh.H" #include "createFields.H" #include "initContinuityErrs.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { Info<< "Time = " << runTime.timeName() << nl << endl; #include "readPISOControls.H" #include "CourantNo.H" fvVectorMatrix UEqn ( (Density)*fvm::ddt(U) + (Density)*fvm::div(phi, U) - (Visc)*(fvm::laplacian(U)) ); solve(UEqn == GravityVector*g*Density*(BetaT*(T-TNot)) - (fvc::grad(p))); //solve(UEqn == -fvc::grad(p)); // --- PISO loop for (int corr=0; corr<nCorr; corr++) { volScalarField rUA = 1.0/UEqn.A(); U = rUA*UEqn.H(); phi = (fvc::interpolate(U) & mesh.Sf()) + fvc::ddtPhiCorr(rUA, U, phi); adjustPhi(phi, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rUA, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(); if (nonOrth == nNonOrthCorr) { phi -= pEqn.flux(); } } #include "continuityErrs.H" U -= rUA*fvc::grad(p); U.correctBoundaryConditions(); } fvScalarMatrix TEqn ( Density*Cp*fvm::ddt(T) + Density*Cp*fvm::div(phi, T) - Cond*(fvm::laplacian(T)) ); TEqn.solve(); //F = Gravity*(1-Beta*(T-TemAmb)); /////////// fvScalarMatrix CEqn ( fvm::ddt(C) + fvm::div(phi, C) ); CEqn.solve(); /////////// // forAll( h, celli) // { // T[celli] = (h[celli] - 1)/Ste.value(); //T[celli] = (h[celli] - L.value())/Cp.value(); // h[celli] = 1 + (Ste.value()*T[celli]); // h[celli] = (Cp.value()*T[celli]) + L.value(); // } /////////// //F = (GravityVector*Pr*T)-(GravityVector*Le*C); //F = gl*GravityVector*g*Density*(1-BetaT*(T-TNot)); F = GravityVector*g*Density*(BetaT*(T-TNot)); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // |
July 24, 2012, 12:26 |
A_R
Rep Power: 16 |
your changes are strange.
for U: fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) == -beta*(T - T0)*g ); for T: solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); where nu is viscosity and DT is conductivity your equation seems have a problem. |
July 24, 2012, 16:41 |
A_R
Rep Power: 16 |
I think that before the GravityVector, you should have (-) |
July 24, 2012, 16:45 |
Rep Power: 13 |
Thank you. But it will not fix the problem. It will only change the direction of U and V.
July 24, 2012, 17:09 |
A_R
Rep Power: 16 |
Can you show a contour of two results?
your case is a bit strange. |
July 24, 2012, 17:10 |
#9 |
A_R
Rep Power: 16 |
at first, I suggest you to solve a forced convection to prove the exactness of the solver then add boussinesqe term to equation.
July 26, 2012, 15:07 |
#10 |
Rep Power: 13 |
I fixed the problem.
The key is in order to get a proper behavior of velocity-pressure coupling in PISO algorithm, I should include the source term inside the velocity equation such that fvVectorMatrix UEqn ( fvm::ddt(U) +fvm::div(phi,U) -fvm::laplacian(ModifVisc,U) == GravityVector*betaT*(T-Tnot) ); solve(UEqn == -fvc::grad(p) ); |
Display Modes | |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 10:26 |
Natural Convection Problem - Helium | marzoa | STAR-CCM+ | 0 | April 18, 2011 15:12 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 19:40 |
natural convection in a sealed enclosure | James | Main CFD Forum | 4 | April 2, 2001 16:48 |
