March 30, 2021, 14:18 |
OpenFOAM computation time
Chris
I am running an incompressible, steady state, internal flow model using the k-w turbulence model. I am running the simulation in parallel on 16 cores. In the middle of refining the mesh checking for mesh independence I noticed the run times seemed to be linearly increasing with the number of elements. This seems strange to me as the NS is a non-linear equation I assumed the run time would increase in an exponential manner as the number of elements increase. Can anyone inform me as to why this is? |
March 31, 2021, 02:39 |
Rep Power: 8 |
what makes the NS non-linear is divergence(uu).
in openfoam this term is linearized -> divergence(u_old u_new), while u_old is the velocity that ensures mass conservation from the old timestep, u_new is the velocity for the new timestep. this way velocity transports itself. for more information i suggest reading Jasak's dissertation. |
March 31, 2021, 11:39 |
Chris
Hey geth03,
Thanks for the information that is very helpful in understanding this situation. |
March 31, 2021, 17:16 |
Daniel P. Combest
Just to add to geth03's answer, we aren't actually solving the linearized integral-differential equation directly. We are solving an implicit linear algebra problem that is linear itself
Ax=b with A being the coefficient matrix (weighting values from the mesh and actual PDE), x being the implicit variable (like temperature or velocity), and b our explicit components. You're seeing the linear scaling because the problem size is growing linearly. Now, this has its limits since as problems grow, there are components in this process that become really difficult to scale linearly or maybe the Ax=b system is too large (or small) for our given number of processors and RAM. If you're interested in Ax=b math, Yousef Saad has a great set of books . His book helped me get started writing the CUDA solvers in OpenFOAM years ago. |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
