anyone tried rhoPorousMRFSimpleFoam in OF 2.0.0?
Old   August 29, 2011, 02:20
Default anyone tried rhoPorousMRFSimpleFoam in OF 2.0.0?
suh
Suhas
suh is on a distinguished road
Hello Foamers,
I am using rhoPorousMRFSimpleFoam for compressor simulation. the mesh is came from starccm+ and checkMesh is ok. Then these are my boundary conditions. I am starting with very slow rotational velocity, i.e. w=1 rad/sec.
for p
inlet-zeroGradient,
outlet-fixedValue, $internalField
wall-zeroGradient internalField uniform 2e5;
for U
inlet-fixedValue, uniform (150 0 0)
outlet-zeroGradient,
wall-fixedValue, uniform (0 0 0) internalField uniform (1 10 10)
for T
inlet-totalTemperature, T0 uniform 300, gamma 1.4
outlet-inletOutlet, value $internalField, inletValue $internalField
wall-zeroGradient, internalField uniform 298;
for mut
inlet-calculated uniform 0,
outlet-calculated uniform 0,
wall-mutkWallFunction uniform 0, internalField uniform 0.018;
for k
inlet-fixedValue, uniform 70
outlet-zeroGradient
wall-compressible: :kqRWallFunction uniform 7, internalField uniform 7;
for epsilon
inlet-fixedValue, uniform 19222.91
outlet-zeroGradient
wall-compressible: :epsilonWallFunction uniform 1922.291, internalField uniform 7;
for alphat
wall-alphatWallFunction uniform 0, internalField uniform 0;
my relaxation factors from fvSolution files are
p 0.1;
rho 1; // I changed this to 0.5 then it ran for about 3500 iterations and then diverges because of thermal properties error message.
U 0.3;
"(k|epsilon)" 0.5;
h 0.5;
and rhomax - 1.9
rhomin - 0.6
and
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1007;
Hf 2.544e+06;
transport
mu 0.1835e-04;
Pr 0.72;
and I am getting this error after 200 iterations.
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (s pecieThermo<Thermo>::*dFdT)(const scalar) const) const
in file /opt/software/OpenFOAM/OpenFOAM-2.0.x/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::ca lculate() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::co rrect() in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/lib/libbasicThermophysicalModels.so"
#4 main in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/bin/rhoPorousMRFSimpleFoam"
#5 __libc_start_main in "/lib64/libc.so.6"
#6 Foam::UOPstream::write(char) in "/share/openfoam/2.0/OpenFOAM/platforms/linux64Gcc45DPOpt/bin/rhoPorousMRFSimpleFoam"
Abort
Please tell me where I am going wrong.
Is anybody using rhoPorousMRFSimpleFoam?
Regards
Suhas
suh is offline   Reply With Quote
Old   August 30, 2011, 06:28
suh
Suhas
Hello Foamers,
Anybody did simulation of compressor using compressible solver of openfoam (main versions)?
I am using OF 2.0.0 and rhoPorousMRFSimpleFoam solver, but I need help to run the simulation.
If anyone has any expirience with this, please give some suggestions...
The simulation is running but there is no pressure increament. why?
Thank you.
Old   July 19, 2012, 11:16
Kalyan
kalyangoparaju is on a distinguished road
I know this is very late but did you solve your problem. The issue can be with the porosity treatment.
I had a similar problem when I was using explicit porosity treatment for high resistance porous region. Changing it to imnkplicit did the trick.
Kalyan
kalyangoparaju is offline   Reply With Quote
Wigley Hull with OpenFoam 2.0.0 problem Stephy OpenFOAM Bugs 19 October 12, 2020 10:22
OpenFOAM 2.0.0 and Turbomachinery lindner OpenFOAM 0 July 8, 2011 07:35
Version 2.0.0 and Intel Compiler muxav OpenFOAM 1 July 4, 2011 08:20
OpenCFD release OpenFOAMŪ version 2.0.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 1 July 1, 2011 08:43
How to Import Gambit 2.2.16 file to Gambit 2.0.0 solomon FLUENT 0 January 4, 2007 14:49
