July 30, 2012, 21:39 |
checkMesh Errors after refineMesh
Matthew Denno
Rep Power: 16 |
I posted this question to the mesh utilities form a few days ago, but thought I would give it a shot here too as I think this section gets more traffic. http://www.cfd-online.com/Forums/ope...efinemesh.html I have a mesh that was created using snappyHexMesh that I am trying to refine using refineMesh, but after running refineMesh, checkMesh gives me errors. I am running an interFoam simulation and am trying to refine the mesh near the air/water interface. In order to use refineMesh, I first created a cellSet using topoSet based on the value of alpha and then used that to define which cells need to be refined. refineMesh completes without errors and based on visual inspection the correct locations seem to be refined. However, when I run checkMesh I get errors. My refineMeshDict and checkMesh output are below. I have tried to use patchLocal coordinates and geometricCut instead, but neither fixed the problem (although the results were different). If I change the directions so that it doesn't refine in the normal direction, checkMesh does not give errors but the refinement is not what I need (i.e. not refined in the z direction). I have also tried to visualize were the problems might be using foamToVTK but don't seem to be able to see the faces in paraFoam, I am guessing because maybe they are too small and spreadout. At this point I am stuck. There don't seem to be very many input parameters to change for refineMesh, so I am not sure what to do next. Thoughts? I have tried it in both 2.1.0 and 2.1.x with the same results. refineMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object refineMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Cells to refine; name of cell set set c0; // Type of coordinate system: // - global : coordinate system same for every cell. Usually aligned with // x,y,z axis. Specify in globalCoeffs section below. // - patchLocal : coordinate system different for every cell. Specify in // patchLocalCoeffs section below. coordinateSystem global; //coordinateSystem patchLocal; // .. and its coefficients. x,y in this case. (normal direction is calculated // as tan1^tan2) globalCoeffs { tan1 (1 0 0); tan2 (0 1 0); } patchLocalCoeffs { patch outside; // Normal direction is facenormal of zero'th face of patch tan1 (1 0 0); } // List of directions to refine directions ( tan1 //x tan2 //y normal //z ); // Whether to use hex topology. This will // - if patchLocal: all cells on selected patch should be hex // - split all hexes in 2x2x2 through the middle of edges. useHexTopology true; // Cut purely geometric (will cut hexes through vertices) or take topology // into account. Incompatible with useHexTopology geometricCut false; // Write meshes from intermediate steps writeMesh false; // ************************************************************************* // Code:
hydro@Bass:rasWES-WithPier-Refined2$ checkMesh -time 0.001 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.x-2ddb0f183f86 Exec : checkMesh -time 0.001 Date : Jul 26 2012 Time : 22:16:52 Host : "Bass" PID : 5559 Case : /home/hydro/OpenFOAM/hydro-2.1.0/run/wes/rasWES-WithPier-Refined2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0.001 Time = 0.001 Mesh stats points: 221480 faces: 597334 internal faces: 560780 cells: 188271 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 176891 prisms: 1590 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 9790 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology top 2050 2271 ok (non-closed singly connected) walls 19801 20838 ok (non-closed singly connected) outlet 960 1055 ok (non-closed singly connected) inlet 819 907 ok (non-closed singly connected) bottom 1586 1757 ok (non-closed singly connected) wes 11338 11835 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-40 0 0) (40 6.33 30) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (5.55089e-16 -9.55142e-16 -1.45354e-15) OK. Max cell openness = 4.41608e-16 OK. Max aspect ratio = 4.53029 OK. ***Zero or negative face area detected. Minimum area: 0 <<Writing 4 zero area faces to set zeroAreaFaces Min volume = 0.000624369. Max volume = 0.13697. Total volume = 12956.9. Cell volumes OK. Mesh non-orthogonality Max: 149.508 average: 6.90896 *Number of severely non-orthogonal faces: 2. ***Number of non-orthogonality errors: 46. <<Writing 48 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 66 faces are incorrectly oriented. <<Writing 33 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 2.66863 OK. Coupled point location match (average 0) OK. Failed 3 mesh checks. End |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[mesh manipulation] checkMesh Erros after refineMesh | mgdenno | OpenFOAM Meshing & Mesh Conversion | 10 | October 14, 2014 05:16 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
