snappyHexMesh and blockMesh not creating mesh in correct region. |
January 19, 2023, 11:37 |
Aaditya
Rep Power: 4 |
Hello, I created a simple model of cylindrical container to perform heat transfer simulation using FreeCAD for CAD modelling. I exported the model in stl format along with domain boundaries and faces. I have attached all the files here.
I have been trying to mesh the container domain. I am using cyclic blockMesh first to create a hex cylindrical block. Next I am using surfaceFeatures and snappyHexMesh to mesh the region inside the cylindrical container. To generate mesh in correct region I located a point using paraview that was clearly within the region where I want the mesh. However, when I check the mesh in paraview, the mesh is generated for wrong region. I tried different point locations but the result turns out to be the same. I have attached the outputs of snappy and blockmesh as well. Could someone help me understand why am I having this problem and how to solve it. Is it a bug in snappyHexMesh? Thank you. |
blockmesh, meshing 3d, openfoam 9, paraview, snappyhexmesh |
Display Modes | |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 10:26 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
[snappyHexMesh] Creating multi region mesh for chtMultiregionFoam | tclph | OpenFOAM Meshing & Mesh Conversion | 1 | December 8, 2020 16:25 |
Error when solving p_rgh | bob94 | OpenFOAM | 0 | March 17, 2020 09:12 |
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh | sazabi2001 | OpenFOAM Meshing & Mesh Conversion | 0 | February 23, 2017 13:00 |
