Execution Time after few iterations very high
Old   September 11, 2012, 04:47
Default Execution Time after few iterations very high
Tobi's Avatar
Tobias Holzmann
I have a question to you. After starting my simulation (~700.000 cells on 10 cores : ~ 70.000 cells per core) the execution time of the first 6 iterations is round about 4 seconds. After that the execution time goes to very high values.
Is that normal? Depends on the cores (too many?)?
Does anyone has some advices?
Thanks tobi
Old   September 11, 2012, 17:27
Retired Super Moderator
Bruno Santos
Hi Tobi,
Are you certain this is a parallel related problem? Doesn't this behavior occur when running in serial?
From your description, it's very hard to assess the reason why this might be happening. It could be due to:
  • NFS acting up, in case you're using more than one machine.
  • The number of iterations for pressure increases considerably. This could be due to various other reasons, such as mesh, fvSchemes, fvSolution....
  • Can also depend on the solver or type of simulation you're trying to perform: simpleFoam, pimpleFoam, interFoam, interDyMFoam, etc etc...
Best regards,
Bruno
Old   September 12, 2012, 03:48
Tobi's Avatar
Tobias Holzmann
Originally Posted by wyldckat View Post
Hi Tobi,
Best regards,
Bruno
Hi Bruno,
thanks for your replay. I have no experience in - how many cores are good for a cfd calculation - that the cores are working good and dont transfer data to each of them.
In that case I think its not a parallel problem
But thanks for your replay. I was just wondering why it is so.
Maybe it is the fact, that I start from a solution and mapped it to the new mesh (extended mesh).
Tobi
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
