Having troubles in understanding the correction term in pressure equation
Old   January 25, 2012, 17:37
Default Having troubles in understanding the correction term in pressure equation
Kai
kaifu is on a distinguished road
I have troubles in understanding the correction term in pressure equation.
For example in buoyantPimpleFoam,
fvScalarMatrix p_rghDDtEqn
    fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh))
  + fvc::div(phi)
where does the term psi*correction(fvm::ddt(p_rgh)) come from?
It seems like it origins from the difference between old value and current value of rho. But how about if we write the eqn as
    fvc::ddt(psi,p)
  + fvc::div(phi)
Back to the correction part, why there is no term like
 p_rgh*correction(fvc::ddt(psi))
Kai
kaifu is offline   Reply With Quote
Old   October 8, 2012, 05:19
pengfei han
pfhan is on a distinguished road
Have you solved it?
I'm confused too. It should be related to the material differential of pressure, but I don't know how to get it in this particular form.
pfhan is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Implicit elliptic pressure field equation. TheBoyce Main CFD Forum 2 June 3, 2011 13:08
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
