Problem when adding temperature to interFoam
Old   November 2, 2012, 00:58
Default Problem when adding temperature to interFoam
HouKen
houkensjtu is on a distinguished road
Hi foamers!
I tried to apply temperature calculation to interFoam according to the hot thread:
http://www.cfd-online.com/Forums/ope...interfoam.html
And what I did was exactly same with the author "ovie" wrote in the #14 reply to the above thread.
Everything compiled well, however when I run it on a two-phase flow case, temperature results near interface was higher than heat source temperature which is surely not reliable result.
Also I test the modified solver to solve for single phase heat transfer calculation, although I didnot do precise validation, temperature field seems to be reasonable. Thus I think the main problem here lies in the interface.
On the other hand, from a theoretical view, no matter interface properties(cp, Pr...) is linear interpolated or harmonic interpolated, interface temperature should be no higher than phase temperature surrounding it.
I cant figure out what is the reason for this problem, plz help!
(Also I am trying to debug it by output cp and other properties on the fly, but I am not sure how to do it elegantly, directly to the console or paraView, plz help ...)
houkensjtu is offline   Reply With Quote
Old   November 4, 2012, 23:10
HouKen
I read the thread post by "ovie" again, and I do find that move the Cp to RHS (i.e., now the TEqn becomes:
fvScalarMatrix TEqn
fvm::ddt(rho, T)
+ fvm::div(rhoPhi, T)
- fvm::laplacian((kappa/Cp), T)
)help the convergence. But from a theoretical view, I believe it's mathematically equal.
So I got even more confused, I think there must be sth. I misunderstood/didn't understood in the whole process.
plz help!
Old   November 5, 2012, 00:29
Nima Samkhaniani
nimasam is on a distinguished road
, i guess it returns to the sensitivity of numerical procedure to calculation of convection terms (flux), those are mathematical the same on the whole domain except at interface but at interface they are a little different, and it can be accepted a new model
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 5, 2012, 01:06
HouKen
Could you be a little bit more explicit on the difference of the interface.(or where can I find related information)
Basically I have only read Patankar and Versteeg's book on cfd and both these books didn't focus much on detailed numerical scheme.
(Another newbie question: I want to output Cp in order to see the space distribution of it(just like T and alpha), how can I do it? plz help!)
Old   November 5, 2012, 02:35
Nima Samkhaniani
if you want to see Cp
just define a volScalarField like T in "creatFields.H"
InterFoam viscosity problem / possible bug pbryant OpenFOAM Running, Solving & CFD 24 March 30, 2020 04:25
Adding temperature equation to porousSimpleFoam David_010 OpenFOAM Programming & Development 9 February 14, 2018 01:22
adding temperature field to icofoam houkensjtu OpenFOAM 5 September 26, 2012 22:20
Interface location problem in interFoam cfd_user2011 OpenFOAM 1 July 7, 2011 12:04
[CFXv11]fluid temperature distr problem mactech001 CFX 1 June 10, 2010 08:08
