November 4, 2012, 09:58 |
SnappyHexMesh issues
I'm a new user of SnappyHexMesh of OpenFoam for mesh. I'm trying to test the capability of this tool and compare it with other software for meshing, so I tried to use very simple geometries like cube, cilinder... I used first the blockMesh tool, then the snappyhexMesh tool and after that I have tested the grid with checkMesh and no problem was shown, but opening the grid with ParaFOAM I see same strange thing in the grid, if I do same sections view. You can look it in the picture attached. I have tried to change settings in my snappyHexMeshdict file but the problem doesn't stop. Is it a visualization issues or a grid probrem? I attacched also my blockMesh and snappyHexMeshDict file. thanks |
November 4, 2012, 14:55 |
Vieri Abolaffio
it is a visualization error typical of paraview.
your cells are not thetraedal but made of "bricks" |
November 5, 2012, 05:08 |
Thanks for the answer,
how can I fix this visualization problem? And another question, when i try to convert the mesh from OF to fluent I obtain the messege below: " FOAM Warning : From function void fluentFvMesh::writeFluentMesh() const in file fluentFvMesh.C at line 252 foamMeshToFluent: cell shape for cell 241613 only supported by Fluent polyhedral meshes. Suppressing any further messages for polyhedral cells. " but the mesh is genereted anyway, the suppression of the polyhedral cells can modify my results ? How can I avoid having polyhedral cells in the mesh? |
November 6, 2012, 08:27 |
#4 | |
Mark Olesen
Rep Power: 40 |
November 6, 2012, 19:59 |
#5 | |
Vieri Abolaffio
there was a thread about that, once upon a time, somewhere in the forum. but i'm afraid I don't remember where... i'm just used to it and don't notice anymore. --edit: my google-fu is batter than i expected, here is the link, try to read the last two messages, Bruno, one of our most prolific forum members, tell you haw to do it! http://www.cfd-online.com/Forums/ope...-parafoam.html don't know, sorry |
grid generation, open foam |
[snappyHexMesh] SnappyHexMesh Issues | deji | OpenFOAM Meshing & Mesh Conversion | 16 | October 20, 2021 07:13 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyHexMesh add-layers issues, warped cells | heling | OpenFOAM Meshing & Mesh Conversion | 9 | August 19, 2013 13:01 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
