November 7, 2012, 09:29 |
mapFields problem
Hugh Ingham
Rep Power: 13 |
Hi everyone,
I am having problems mapping fields from a coarser mesh to a finer mesh using mapFields in a parallel simulation. My source (low res) case was run in parallel (the domain is decomposed into 24 subdomains) and the geometry and boundary conditions are consistent with my target case. So initially I decomposed my target (high res) case first then performed mapFields using the following tags: - consistent - parallelSource - parallelTarget However this didn't work. I then reconstructed my source case and then used this single time directory to map to the decomposed target case using the following tags: - consistent - parallelTarget But this still didn't work. I then just tried to mapFields from the single reconstructed time directory to a single target before decomposing the domain using the following tags: -consistent and it still didn't work. For every method I tried the result was the same: it never seemed to even start. You can see this in the shell output below: | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : mapFields hming1@msgln6.its.monash.edu.au:SCRATCH/NEW-SCRATCH/1100k_3 -case . -consistent Date : Nov 08 2012 Time : 00:41:55 Host : "gn139.its.monash.edu.au" PID : 28321 Case : /scr-nfs/stefano-2012/hming1/3900k_1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "hming1@msgln6.its.monash.edu.au:SCRATCH/NEW-SCRATCH" "1100k_3" Target: "/scr-nfs/stefano-2012/hming1" "3900k_1" Create databases as time Does anyone have any idea how to fix this? Thanks |
November 8, 2012, 13:42 |
anonymous
You need to create initial data files in your target directory. The target directory and the source directory need to be at the same time.
mapfields, parallel processing |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
