Putting it on GitHub without asking and without a link to the original place is not very nice. Jörn |
Fatal Error running karman case
i downloaded the case and ran pimpleFoam but Fatal Error.. "Starting time loop Courant Number mean: 0.16928 max: 2.70568 Time = 0.001 --> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 32 the label 1 file: /storage/rababqjt/tutorials/Karmann_OpenFoam/karmann_gridpro_pimple/system/fvSchemes.divSchemes.div((nuEff*dev2(T(grad(U))))) at line 32. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&) in file primitives/strings/word/wordIO.C at line 74. FOAM exiting " do you have any idea how i can solve this error? |
I've made some changes and tested it with v1912. So it should work now. Have fun.
its still having a problem, i am running the Openfoam 6 version...
What are exactly the steps to run the simulation? I figure since mesh is already there, we need only to: 1. decomposePar 2. pimpleFoam 3. reconstructPar 4. paraview are these the correct steps? where is the problem? thanks! |
I made a tutorial, you can find the files in my repository: https://www.youtube.com/watch?v=A1YQ9eZQFcg
thanks, i was struggling with the Allrunscript and how it works, glad to know how it works now :) |
