January 26, 2011, 14:22 |
thobois class engineTopoChangerMesh error
#1 | |
Rep Power: 16 |
Hi
I try to set up an engine mesh with canted valves and piston layering. Therefore, I chose the thobois class in the engineTopoChangerMesh class. I already succeed in running a case with the accordionEngineMesh class but with thobois class, i got the following error. I am running it on 1.6-ext. Quote:
Remark: I had to change the addAttachDetachFacesThoboisMesh.H file with addAttachDetachFacesAccordionEngineMesh.H. Otherwise I couldn t create the meshModifiers. The thoboisMesh class looks very similar to the accordionEngineMesh class, but with piston layer. Peter |
January 27, 2011, 10:08 |
Rep Power: 16 |
I solved the problem.
I have changed in the motionU file the boundary conditions for the piston to componentMixed. Does anyone knows what is meant by this bc§? I don t understand this boundary conditon. How to set it up? Anyway the case isn t still working properly. Peter |
June 8, 2011, 08:12 |
Rep Power: 15 |
Hi Peter,
I am trying now to do the same, tilted valves and piston layering. I am working on the thobois class but started also with the accordionEngine class following your posts, but I can't get it to work. What changes did u need to do? All the point, face and cell Zones for moving and static parts are created, but I am quite confused cause they dont get written as mesh modifiers in any way, so don't know if the code is complete or not :S any ideas? would appreciate it |
May 4, 2013, 08:19 |
ILAM
Rep Power: 13 |
Hi Peter,
I want to do a 3D engine simulation (cold flow) with canted valves. can u please share a tutorial? |
August 2, 2014, 09:52 |
Using Thobois ?
Amrinder Singh
Rep Power: 13 |
Hello Peter
I am doing PhD in CFD in Mechanical Eng. Department, I am trying to simulate 4 stroke diesel engine with flat head and canted valves around 4 degree. I am trying to use thobois class in OpenFoam Ext 3.1 Am I using right class? I think you have successfully implemented this class and i think no would better know about this class than you. I have some queries about some keywords definitions? detachFaces movingPoints movingInternalPoints staticCells movingCells staticPointsName any demo case or any kind of information would be really helpful. Thanks Amrinder Singh |
Display Modes | |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
