Reference on the Lack of Uniqueness of the Cell Volume
Old   December 19, 2012, 08:58
Default Reference on the Lack of Uniqueness of the Cell Volume
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good afternoon to all of you,
I have for a while been looking for a reference, which discuss the volume of a general hexahedral cell, i.e. non-planar faces.
I have found some references which hint that the volume of such a hexahedral cell is not uniquely defined, and based on some practical tests with different methods to compute the volume, I have reached the same conclusion.
Nonetheless, I would be grateful if anyone of you know about an article, which directly addresses the non-uniqueness in evaluating the volume of a general hexahedral cell.
Thank you and Merry Christmas,
Niels
ngj is offline   Reply With Quote
Old   December 19, 2012, 13:03
Sandeep Menon
deepsterblue will become famous soon enough
Why just hexahedral cells? Any general (non-simplical) polyhedral cell with non-planar faces would apply.
It depends on how you decompose the cell during the calculation. I've seen that a face-and-cell decomposition gives the best results.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   December 19, 2012, 13:14
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
If every face is decomposed consistently, I believe the errors in volume will at least cancel out globally.
kmooney is offline   Reply With Quote
Old   December 19, 2012, 17:09
ngj
Good evening,
Thanks for your replies.
Right now I am working on an article, where I have found myself in the need to compute the volume of a general hexahedral in order to prove a conservation property, however, since the volume appears to be non-uniquely defined, I find myself unable to give a full proof. Therefore, I would like to be able to refer to a firm/non-arguable statement/proof/article that the volume is indeed non-unique.
Kind regards,
Niels
Old   December 19, 2012, 19:05
kmooney's Avatar
Kyle Mooney
Hi Niels,
This paper:
http://citeseerx.ist.psu.edu/viewdoc...0.1.1.226.4098
mentions that without an expression for the surface that comprises a non-planar face, there is no information available to define it (pg. 5) and you need to make something up and approximate before decomposition. The fact that you need to base your decomposition on some approximation, and volume is a function of that decomposition, tell me that it is not unique.
This paper (sec. 4.2):
http://dl.acm.org/citation.cfm?id=614335
Mentions that you need to be consistent in decomposition. Since you have different options when decomposing a polyhedra, I'm thinking this implies that you can get different volume calculations.
If you search around for "tetrahedral subdivisions" or words like that you should find some more useful info. Sorry I can't give you a concrete answer on this.
Cheers!
Kyle
Old   December 20, 2012, 04:24
ngj
Hi Kyle,
Thank you, I think those references should do the trick - at least they lend sufficient support to my arguments
Merry Christmas,
Niels
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
OF211: ThirdParty and /src compiled, but not /applications... vkrastev OpenFOAM Installation 8 October 18, 2012 15:53
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
