Allclean deletes blockMeshDict file!
Old   December 2, 2011, 09:23
Default Allclean deletes blockMeshDict file!
musaddeque hossein
musahossein is on a distinguished road
Dear all:
I am running OpenFOAM on Ubuntu 11.10. I modfied the blockmeshDict.m4 file in sloshingtank2D and saved it as blockmeshDict and modified the Allrun file accordingly. All works well. But strangely, when I do Allclean, it not only deletes the files it is supposed to delete, but also deletes the modified blockmeshDict file! is this bizzare behaviour a legacy of Ubuntu or the new OpenFOAM? Help!
musahossein is offline   Reply With Quote
Old   March 17, 2013, 17:56
Default how to disable blockmesh.m4 in openfoam 2.2.0
musaddeque hossein
Hi:
I need to disable the blockmesh.m4 file as I want to run my blockmesh file. However, interdymfoam keeps looking for the blockmesh.m4 and ignores the blockmesh that I have. Any solution to this will be greatly appreciated, thanks.
Also, Allclean wipes out the contents of the blockmesh file. How can this be prevented? I am running Openfoam 2.2.0 on Ubuntu 12.10.
Thanks!
Old   March 18, 2013, 17:17
Retired Super Moderator
Bruno Santos
Greetings musahossein,
Allclean is removing the "blockMeshDict" file automatically because "constant/polyMesh/blockMeshDict.m4" also exists. Try moving the file to another folder and adjust the Allrun script to run use m4 with the new location, but also sending the generated file into the correct location "constant/polyMesh/blockMeshDict".
To help explain further, it would help to know which tutorial case you are referring to!
Best regards,
Bruno
Old   March 18, 2013, 19:41
musaddeque hossein
Thankyou. I realized that right after posting that question and felt quite foolish. Thanks again for your effort.
Old   March 18, 2013, 19:46
Default Wall pressure is now in Post processing?
musaddeque hossein
Dear all:
I am running OpenFoam 2.2.0 on Ubuntu 12.10. I am running sloshingTank2D. I noted that wall pressures are now being stored under post processing folder. Is this just to organize the output files in a meaningful way, or is there a more compelling reason. Just curious.
Old   March 28, 2013, 20:39
Default Cant seem to change the write times for wall pressure p and phase files in slosingtan
musaddeque hossein
I have another question. If I run the sloshingTank2D in interDyMFoam, the wall pressures are output to the post processing file. The files are printed at intervals of 0.1, 0.2 etc. I however want the output at 0.02, 0.04 etc. I modfied the writeInterval in the controlDict file at 0.02. However the output is still 0.1, 0.2, i.e. unchanged. How can I modify control dict so that the files are written at 0.02, 0.04 etc?
Thanks
Old   April 1, 2013, 08:26
Bruno Santos
Hi Musaddeque,
I've moved your posts on the last couple of questions to this thread: http://www.cfd-online.com/Forums/ope...a.htmlI'll try to answer your questions on that thread as soon as I can.
Best regards,
Bruno
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
