good convergence but bad display
Like Tree4Likes
  • 1 Post By norkistar
  • 1 Post By Traib
  • 1 Post By Traib
  • 1 Post By zaynah04
Old   January 8, 2013, 15:37
Default good convergence but bad display
zaynah K.
zaynah04 is on a distinguished road
Dear members,
my solution iterate ..
when i display on paraFoam i get bad results.
example for Pressure i obtain only RED everywhere and for velocity i get the Blue everywhere..
Can any one please guide me..
zaynah04 is offline   Reply With Quote
Old   January 8, 2013, 21:45
Bin Xu
norkistar is on a distinguished road
Can you give some details about your problem and the results that we can have a look?
zaynah04 likes this.
norkistar is offline   Reply With Quote
Old   January 9, 2013, 02:14
zaynah K.
hi thanks for your reply.
I have achieved iteration and when i display in paraFoam, i get bad results. by bad results i mean that for the pressure display i get red color in the whole region! and in velocity contour i get Blue colour in the whole domain region..
i have used the Glymph filter as instructed in the manual before display my velocity contour.
I think i have not been able to use the paraview settings as per regulations.
can you please guide me?
thanks
Old   January 9, 2013, 02:28
Bin Xu
Hi I think you might need to refer to the user guide of the paraview and then become familiar with how to use it since you can display pressure and velocity using Glymph filter
Cheers
Old   January 9, 2013, 02:31
zaynah K.
I had actually read the user manual and follow the steps..
this is why i am posting my problem..
Old   January 9, 2013, 02:36
Bin Xu
Can you list the step that you did here that we can have a look in detail?
Old   January 9, 2013, 02:58
zaynah K.
1- in display panel i choose U for display of velocity
2- in glymph filter i choose glymph arrow, scale factor to 0.005.
then i display it all...
and for pressure..
i choose p for display pressure and rescale to data range and also i choose surface,,,
Old   January 9, 2013, 03:01
Bin Xu
then i think after you choose U, you should choose magnitude just at the rightside of U
Old   January 9, 2013, 03:05
zaynah K.
i did choose that..
Old   January 9, 2013, 03:15
Bin Xu
you choose surface at the rightside of magnitude?
Old   January 9, 2013, 03:18
zaynah K.
surface was chosen for style presentation!
Old   January 9, 2013, 07:13
Traib
Traib is on a distinguished road
Hi zaynah,
Its difficult to guess from your description coz you have tried most of the stpes already but just to check
1. are you running the simulation in parallel? If yes, did you do 'reconstructPar'?
2. did you try 'rescale to data range' at following time steps? sometimes for slower systems the data takes some time to load so the calculated data appear after some time. I get this problem when I am using my laptop which is quite slow, so I go back and forward in time steps and rescale.
3. did you check the time text files to see the calculated data values? Just in case
4. or like user norkistar said, you could attach more details so that we could have a look.
Regards,
Traib
Traib is offline   Reply With Quote
Old   January 9, 2013, 09:07
zaynah K.
Hi traib,
no i not run in parallel and yeah i rescale to data range ..
i have attached the picture..
below is part of the result of iteration..
Time = 10
Courant Number mean: 4.89461e-06 max: 9.43364e-05
DILUPBiCG: Solving for Ux, Initial residual = 0.000645717, Final residual = 3.21458e-06, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00104037, Final residual = 3.59143e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.00184126, Final residual = 9.98725e-07, No Iterations 293
DICPCG: Solving for p, Initial residual = 9.24984e-05, Final residual = 9.73594e-07, No Iterations 100
DICPCG: Solving for p, Initial residual = 5.70579e-06, Final residual = 9.16013e-07, No Iterations 4
time step continuity errors : sum local = 2.79268e-16, global = 2.18109e-17, cumulative = 5.8943e-13
DICPCG: Solving for p, Initial residual = 0.00019026, Final residual = 9.77781e-07, No Iterations 274
DICPCG: Solving for p, Initial residual = 2.72308e-05, Final residual = 9.93397e-07, No Iterations 33
DICPCG: Solving for p, Initial residual = 2.03678e-06, Final residual = 8.69365e-07, No Iterations 1
time step continuity errors : sum local = 2.65075e-16, global = -4.99172e-20, cumulative = 5.8943e-13
ExecutionTime = 1881.44 s ClockTime = 1884 s
End
Old   January 9, 2013, 09:51
Traib
Hi zaynah,
It appears the calculated values are infact loaded into paraview as they are in your calculation results. Check the U and p files in time directory 10 to go through the numbers and see if there are values of pressure calculated as you desire. If you don't see the expected values there, check the problem set up to see if you are missing anything. From the iteration results you have attached the calculation is not yet close to convergence seen from the nonidentical residual values.
Regards,
Traib
Old   January 9, 2013, 10:11
zaynah K.
i had make the iteration up to 1e-4..
to acheive convergence what mst i do?
Old   January 9, 2013, 14:14
Traib
Firstly, you need to make sure that your case has been set up correctly. Then you can run the calculation to a time where the residual errors are acceptably small, which is depending on the tolerance values for variables you define in fvSolution dictionary for your case. However, like I said, first you need to make sure your case set up is correct. I also see that your maximum courant number has dropped to about 1e-4 which is very low, values around 0.5 should be good enough for your calculation. You can add 'runTimeModifiable' and 'adjustTimeStep' in your controlDict to automatically adjust the time steps to more appropriate values and see how the calculation works for a try.
Old   January 9, 2013, 14:32
zaynah K.
i did as u suggested and my courant number remained low..
and same result..
Old   January 10, 2013, 01:00
zaynah K.
hi i have been able to do it.
dear Traib and Bin xu
i had used the cell centres incorrectly ..now its all fine..
thank you all for your help..
zaynah
Traib likes this.
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
SimpleFoam solution convergence pattern philippose OpenFOAM Running, Solving & CFD 0 June 26, 2008 14:18
convergence problems using SBF=1 Fonzie CFX 1 March 23, 2007 08:46
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
