Supersonic flow with rhoCentralFoam
Old   January 29, 2013, 04:24
Default Supersonic flow with rhoCentralFoam
Robin Debroux
robdeb is on a distinguished road
Hi everybody,
I'm trying to simulate a supersonic flow in a convergent-divergent nozzle with rhoCentralFoam.
I have a problem with my inlet boundary conditions:
I impose a totale pressure and use pressureInletVelocity for the velocity.
The problem is that I would like to impose (0 0 0) as value of the pressureInletVelocity condition but when I do this, I get a "floating point exception". When I impose a non-zero value, it works but it doesn't give me the expected results.
When I use sonicFoam with the same conditions, everything goes well. The aim of using rhoCentralFoam is to compare the two solvers, so I need some help.
Thank you.
robdeb is offline   Reply With Quote
Old   January 29, 2013, 11:28
Valentin Wibaut
vwibaut is on a distinguished road
Hello
I have the same problems with rhoCentralFoam and I also try to simulate the flow in a nozzle. But when I impose a different value for the velocity I have the same error (after more iterations).
Do you find the problem robdeb?
Regards
vwibaut is offline   Reply With Quote
Old   January 31, 2013, 04:20
Robin Debroux
Hi Valentin,
Yes, I get the same problem. I think the problem come from the fact I set a to big inlet pressure compare to my outlet pressure (inlet: 1100000, outlet : 101325) and the solver can't handle it. I try a setField to divide my domain and impose a pressure that decrease slowly to the outlet value but it didn't solve anything.
If anybody has a solution, it would be great.
Thank you.
Old   January 31, 2013, 11:09
Mahdi Hosseinali
anishtain4 is on a distinguished road
Originally Posted by robdeb View Post
Hi everybody,
Thank you.
I believe rhoCentralFoam uses absolute pressure in the thermophysical model, so when you set it to zero it is just physically meaningless to it.
and by the way, in my personal experience rhoCenralFoam is a little bit fragile in comparison with say rhoPimpleFoam
anishtain4 is offline   Reply With Quote
Old   January 31, 2013, 11:23
Robin Debroux
Thank you for your reply.
But when I set the velocity to a non-zero value, it makes more iterations, but I get the same error as vwibaut said it.
Old   January 31, 2013, 14:31
Mahdi Hosseinali
Check the courant number, it's a matter of wave propagation, you may play with some stuff to hinder it but if you set the case in a manner that leads to it, it will be inevitable.
Old   January 31, 2013, 18:17
Valentin Wibaut
The courant number seems to be good. Moreover we give an upper limit in the controldict file so it is not our problem.
Old   February 1, 2013, 04:23
Mahdi Hosseinali
this error means a variable is being out of range (divide by zero, or negative in sqrt, etc) and this usually happens when the physical modelling collapses. To see what is wrong set very small time steps so you may get many runs and have some written data before the core gets dump. Then view your flow and report what is getting out of order first?
Old   February 1, 2013, 14:47
maHein is on a distinguished road
What did you use as initial conditions for U? I would recommend to use values which are close to the final expected axial speed. Furthermore, you could try to steadily increase the total pressure at the inlet in order to avoid extreme pressure and velocity gradients within the first iterations.
maHein is offline   Reply With Quote
Old   February 2, 2013, 05:33
Valentin Wibaut
Hi mahein,
First, thanks for your reply.
For U, I have
inlet
type pressureInletVelocity;
value uniform (0 0 0);
outlet
type zeroGradient;
I have used values wich are given by sonicFoam just before convergence and with that no more "floating point exception" error but there is another problem. The solver rhoCentralFoam doesn't give a (good) solution and never stabilize although the initial conditions are close to convergence. When I look at the solution at the different time step, I can see that the cells at the inlet have high pressure. And this pressure increases with time. I don't know if this is the cause of the no convergence.
Other test I made,
I use setFields to impose different pressure in the nozzle and decrease the pressure and velocity gradient for the first iterations. There is no more floating point exception but the solution is wrong!! I thtink I'll try to use a time varying condition.
Thank you very much for your help for the floating point exception
Old   February 3, 2013, 07:32
I also experienced unphysical pressure distributions at the inlet when using "pressureInletVelocity" for U at the inlet. Try "pressureInletOutletVelocity" instead. It improved my results.
Old   February 4, 2013, 08:58
Valentin Wibaut
I have tested "pressureInletOutletVelocity" :
inlet
type pressureInletOutletVelocity;
But this doesn't solve the problem
Old   February 6, 2013, 04:30
Valentin Wibaut
When I replace the boundary condition for the velocity (pressureInletVelocity) by zeroGradient, I have the same problem. An idea??
For the other problem, I try with setFields but always the problem of wrong solution. Somebody has an idea about how to solve this problem?
Old   February 11, 2013, 05:43
Valentin Wibaut
I see on other threads that there is problem with rhoCentralFoam when using totalPressure and/or totalTemperature. But why? I don't understand
Old   February 18, 2013, 03:09
Sami
abdul Sami is on a distinguished road
Plz tell me the terms, static pressure, total pressure, static temperature and total temperature with respect to convergent divergent nozzle I m so worried plzz help me I will be thankful
abdul Sami is offline   Reply With Quote
Old   February 19, 2013, 03:12
Mahdi Hosseinali
read a book like the one by anderson in gas dynamic
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech enriccasas FLUENT 1 August 21, 2013 06:43
Flow in Supersonic MHD Channel Antanas CFX 6 February 13, 2012 14:49
Modeling Bleed in Supersonic Flow Mohd Yousuf Ali FLUENT 0 March 17, 2007 03:51
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
