adjust volscalarfield
Old   February 13, 2013, 06:04
Default adjust volscalarfield
v
vahidzanganeh is on a distinguished road
hi foamers
i will want to constant volscalarfield (Tsol ) in particular time and place. But using the following code does not work properly. and Tsol is not adjust!!
for (int i=0;i<U.size();i++)
if( runTime.value() > 0.1 && runTime.value() < 0.3 )
if (mesh.C().internalField()[i][0] > 0.031 && mesh.C().internalField()[i][0] < 0.08 && mesh.C().internalField()[i][1] > 0.001 && mesh.C().internalField()[i][1] < 0.009 )
Tsol.internalField()[i]=1200.0;
who can help me?
best regards
vahidzanganeh is offline   Reply With Quote
Old   February 13, 2013, 09:06
Mahdi Hosseinali
anishtain4 is on a distinguished road
Where are you adding this code?
Does it change something but that is not what you want? Or there it does not affect your field at all?
there two points in solution, first change the order of for loop and if, so for every grid cell and every iteration it don't check the time. Second I never recommend to use for to loop over OF objects, instead of that try using forAll.
anishtain4 is offline   Reply With Quote
Old   February 13, 2013, 17:31
conceptone is on a distinguished road
Hi, you can just define a volscalarfield like:
const volscalarfield T
then T would be a constant field,but you need to give the initialised value.
conceptone is offline   Reply With Quote
Old   February 14, 2013, 01:44
v
thanks your reply
i added my reactingFoam.C (in pimple loop)after solved hs and Tsol eqn(Tsol equation is new equation). Tsol is porous medium temperature and Tsol was increased in order to simulation ignition.
#include "hsEqn.H"
#include "TsolEqn.H"
Old   February 15, 2013, 03:34
Mahdi Hosseinali
It seems right but I can understand why you are not getting what you want? Did you see any change after adding this section? Trying increasing it to a dramatic value and see what happens?
also check the limiters you may have been set somewhere else, there is a possibility you've been clipped temperature to a value way below 1200
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
if-loop, volScalarField comparison volker OpenFOAM 7 March 6, 2020 20:03
Problems with creating a volScalarField georlade OpenFOAM Programming & Development 4 December 4, 2016 12:31
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
dimensionedScalar + volScalarField is evaluated elementwisely ? tianyikillua OpenFOAM Programming & Development 1 March 30, 2012 03:12
