February 8, 2013, 16:05 |
Errors in compiling ccm26ToFoam
Rep Power: 13 |
This is my very first post to this great forum that I have been lurking for ages
But I am getting more serious with OpenFoam and it's time to ask you guys for help. So, I followed the instructions on the other thread from 2012, post #37 here: http://www.cfd-online.com/Forums/ope...#post365682#37 But I get the following when I try to compile ccm26ToFoam: A few remarks first: 1. I compiled OpenFoam 2.1.1 on the 64bit Centos 6.3 VBox installation, everything seems to be fine. 2. The CD Adapco rep sent us the links to download libccmio version 2.06.024, I'm no expert on the company's version numbering so is this a more recent version to 2.6.1 that is required by ./AllwmakeLibccmio (both the default one & the one in the post above)? Or is it an older version? 3. I renamed the folder (after decompressing libccmio.tar.gz) to libccmio-2.6.1 in order for the default ./AllwmakeLibccmio to work which I think it did. 4. Now, when I follow the post linked above, namely, when I do: Code:
cd $WM_PROJECT_DIR/applications/utilities/mesh/conversion/Optional/ccm26ToFoam wmake Code:
SOURCE=ccm26ToFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/MyHome/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/MyHome/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/MyHome/OpenFOAM/ThirdParty-2.1.1/libccmio-2.6.1 -I/home/MyHome/OpenFOAM/ThirdParty-2.1.1/libccmio-2.6.1/lnInclude -IlnInclude -I. -I/home/MyHome/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/MyHome/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/ccm26ToFoam.o ccm26ToFoam.C: In function ‘void ReadVertices(CCMIOError&, CCMIOID&, Foam::labelList&, Foam::pointField&)’: ccm26ToFoam.C:188: error: ‘CCMIOSize’ was not declared in this scope ccm26ToFoam.C:188: error: expected ‘;’ before ‘nVertices’ ccm26ToFoam.C:189: error: ‘nVertices’ was not declared in this scope ccm26ToFoam.C:204: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘3’ to ‘CCMIOError CCMIOReadVerticesf(CCMIOError*, CCMIOID, CCMIOSize_t*, float*, CCMIOID*, float*, CCMIOIndex_t, CCMIOIndex_t)’ ccm26ToFoam.C:205: error: conversion from ‘int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C: In function ‘void ReadProblem(CCMIOError&, CCMIOID&, const Foam::Map<int>&, Foam::Map<Foam::word>&, Foam::wordList&, Foam::wordList&)’: ccm26ToFoam.C:246: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C:283: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C: In function ‘void ReadCells(CCMIOError&, CCMIOID&, Foam::labelList&, Foam::labelList&, Foam::Map<int>&, Foam::DynamicList<int, 0u, 2u, 1u>&, Foam::DynamicList<int, 0u, 2u, 1u>&, Foam::labelList&, Foam::labelList&, Foam::labelList&, Foam::faceList&)’: ccm26ToFoam.C:409: error: ‘CCMIOSize’ was not declared in this scope ccm26ToFoam.C:409: error: expected ‘;’ before ‘nCells’ ccm26ToFoam.C:410: error: ‘nCells’ was not declared in this scope ccm26ToFoam.C:433: error: expected ‘;’ before ‘nInternalFaces’ ccm26ToFoam.C:434: error: ‘nInternalFaces’ was not declared in this scope ccm26ToFoam.C:442: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C:446: error: expected ‘;’ before ‘size’ ccm26ToFoam.C:447: error: ‘size’ was not declared in this scope ccm26ToFoam.C:465: error: expected ‘;’ before ‘size’ ccm26ToFoam.C:466: error: ‘size’ was not declared in this scope ccm26ToFoam.C:470: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C:473: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C:474: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C:506: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C:510: error: expected ‘;’ before ‘nFaces’ ccm26ToFoam.C:511: error: ‘nFaces’ was not declared in this scope ccm26ToFoam.C:519: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C:521: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C:522: error: conversion from ‘long unsigned int’ to non-scalar type ‘CCMIOIndex_t’ requested ccm26ToFoam.C: In function ‘int main(int, char**)’: ccm26ToFoam.C:659: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C:663: error: cannot convert ‘unsigned int*’ to ‘CCMIOSize_t*’ for argument ‘3’ to ‘CCMIOError CCMIOEntityDescription(CCMIOError*, CCMIOID, CCMIOSize_t*, char*)’ ccm26ToFoam.C:674: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ ccm26ToFoam.C:756: error: cannot convert ‘int*’ to ‘CCMIOSize_t*’ for argument ‘4’ to ‘CCMIOError CCMIONextEntity(CCMIOError*, CCMIOID, CCMIOEntity, CCMIOSize_t*, CCMIOID*)’ make: *** [Make/linux64GccDPOpt/ccm26ToFoam.o] Error 1 Thanks. |
February 10, 2013, 06:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sudo and welcome to the forum!
Perhaps it's best that you ask for the specific version 2.6.1, if possible. From a quick search, I found this post: http://code-saturne.org/forum/viewtopic.php?f=8&t=987 In essence, according to the information on that thread, Code-Saturne is probably also not compatible with libccmio versions above 2.6.1 as well. After you've managed to build with 2.6.1, maybe you'll more easily be able to upgrade the code to build with libccmio 2.6.24. Best regards, Bruno
February 15, 2013, 09:47 |
Rep Power: 13 |
Thanks Bruno, I contacted our CD Adapco rep and he said they do not keep repository of older versions. He suggested trying to modify the script to adapt it to the new version (2.06.024), I am not sure how hard or even possible this is going to be. Any ideas?
February 15, 2013, 10:17 |
Bruno Santos
Rep Power: 128 |
Quick answer: you can find the old version 2.6.1 embed into the following script: https://github.com/ogoe/OpenFOAM-1.6...mio-2.6.1.spec
February 15, 2013, 13:43 |
Rep Power: 13 |
Bruno,
Thanks for your quick response, but unfortunately all the ftp links are not working from here, and the Lawrence Livermore VISIT's Third Party directory link is 404. |
February 15, 2013, 17:22 |
Bruno Santos
Rep Power: 128 |
I had no idea they had taken it out... well, googling for "libccmio-2.6.1.tar.gz" still brings some old copies back into light...
But I'm starting to see that it's best to request a copy of the latest library version, so that the ccm26ToFoam application can be upgraded...
February 17, 2013, 16:33 |
The solar system
Rep Power: 13 |
Thanks, Bruno
- I did a search for libccmio 2.6.1 and I downloaded it, it's about 30MB uncompressed in size, no? - CD Adapco already sent the latest version of their libccmio, version 2.06.024, which I believe is their latest version. The errors I posted in the first thread were from running the Allwmakelibccmio that came with OF with the latest version. - I'll try compiling with the 2.6.1 version tomorrow and report back. |
ccm26tofoam, linux64 |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
