momentum source and pressure oscillation
Old   April 1, 2013, 14:19
Default momentum source and pressure oscillation
Max Meinicke
maxmeinicke is on a distinguished road
Hi guys,
I am solving a case with a solver derived from pimpleFoam 2.2.x, where I add a momentum source term into the UEqn.
When solving and watching the initial residual for pressure p, oscillation occurs. With disabled momentum source, no oscillation occurs. The initial pressure residual alternates every time step with magnitude of 10.
Example:
timesteps 2n: 1e-4
timesteps 2n+1: 1e-5
The boundary conditions should be okay since the case is a channel with inlet and outlet. I am using k-e turbulence model.
I followed http://www.cfd-online.com/Forums/ope...-too-high.html. Didn't help...
So maybe someone has a solution or similar problems...
Maybe there is a problem with the pressure correction...
Feel free to answer
maxmeinicke is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Pressure drop momentum source model delic Main CFD Forum 0 June 1, 2012 21:58
Pressure jump and momentum source Tanya FLUENT 1 June 4, 2009 15:22
total pressure drop and momentum source setting Li CFX 2 July 28, 2008 02:33
2D momentum source for pressure loss Bernhard Dobmeier CFX 0 December 5, 2006 04:05
