Katabatic flow using buoyantboussinesqpisofoam
Old   April 18, 2013, 10:30
Default Katabatic flow using buoyantboussinesqpisofoam
tsauter is on a distinguished road
Hi all,
I am using a bouyantBoussinesq solver (LES) to model a katabatic wind flow along a slope. The surface temperature (wall) is slightly cooler than the overlying stably stratified atmosphere (see figure 1).
I like to use cyclic boundary conditions for the left and right patch, in order to get a fully developed turbulent wind field. Since the inlet and outlet are not at the same height, this causes a jump of the pressure field (see picture 2).
It is probably not possible to use a cyclic boundary condition here, or is there a way to solve this problem?
The other solution might be to rotate the frame of reference by aligning the x-axis with the slope, but I am not quite sure how to do this.
Thank you in advance
Tobias
tsauter is offline   Reply With Quote
Old   April 19, 2013, 03:43
Nima Samkhaniani
nimasam is on a distinguished road
you can use cyclic BC with pressure Jump, pressure Jump can be accessed by fan type BC at inlet-outlet, search in forum about fan BC
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   April 19, 2013, 04:05
Hi Nima Sam,
Thank you very much for your response. I'll check it out.
Cheers,
Tobias
Old   April 19, 2013, 09:09
Hi Niam,
I have applied the following boundary conditions to the left and right patch, respectively. But the result is still the same. Do I make something wrong?
left
        type             fan;
        patchType     cyclic;
        jump           uniform 0;
        f                 2(100 -1.0);
        value           uniform 0;
    right
        type             fan;
        patchType     cyclic;
        jump            uniform 0;
        f                 2(100 -1.0);
        value           uniform 0;
Thank you very much.
Tobias
buoyantboussinesqpisofoam, cyclic boundaries, les model, pressure boundary
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
