November 6, 2011, 07:28 |
Turbulent Length Scale
Lluís M. Biscarri
Rep Power: 14 |
I'm running a case with simpleFoam, stationary flow
I'd like to know how to estimate the Turbulent Length Scale, which by default is set to 0.125 (I use Discretizer to setup OpenFoam cases) I understand this parameter has relation with the Viscous Wall Layer, and may be deduced from the expression NU/U*, being U* the Friction Velocity which is defined as sqrt(shear_stress/rho) The question is how to estimate near wall shear stress in order to calculate the Turbulent Lenght Scale, or if there is an easier rule to obtain this parameter. Thanks for the comments, |
November 7, 2011, 04:26 |
turbulent length scale
supercommandodhruv
Rep Power: 14 |
November 8, 2011, 04:32 |
Lluís M. Biscarri
Rep Power: 14 |
thank's a lot, Dhruv
October 11, 2016, 23:15 |
UHGAR
Rep Power: 9 |
Hi, Foamers!
Can I get your valuable suggestions? I would like to track the Turbulent length scales at every time step and use it in paraFoam as well in quantitative post processing. How can I do it? How the length scales field will be created just like u,p, k etc., ? Thanks, UHGAR |
Turbulent Length Scale and Intensity for Airfoil | shamim | STAR-CCM+ | 2 | July 12, 2017 23:11 |
Integral Length Scale vs Turbulent Length Scale | Scott Nordsen | FLUENT | 2 | January 20, 2014 01:17 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 07:28 |
how to calculate Turbulent Length Scale | nuimlabib | Main CFD Forum | 2 | August 18, 2009 04:22 |
Turbulent Characteristic Length/Turbulent Length Scale | fluentnoob | FLUENT | 2 | July 3, 2009 08:40 |
