I want to set normal velocity 0 at boundary
Old   November 21, 2019, 15:15
Default I want to set normal velocity 0 at boundary
rucky96 is on a distinguished road
I have a cylinder (axisymetric in z direction) as computational domain. Inlet and outlet are periodic. I want to to set normal velocity 0 at the sides.
The slip condition just do not allow velocity to go outwards. But it can point inwards with non 0 normal component. I do not want this.
The noSlip condition could works but I do not need to give a 0 value to the tangent components.
I tried with directionMixed writing the following:
    sides
        type             directionMixed;
        refValue         uniform (0 0 0);
        refGradient     uniform (0 0 0);
        valueFraction   uniform (0 0 0 0 0 1);
But I just get 0 in z component, which is the opposite that I want. I want 0 in radial direction and whatever in azimutal and z direction.
Could anyone help me?
rucky96 is offline   Reply With Quote
Old   November 27, 2019, 16:19
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
How would 'slip' condition allow non-zero inward velocity?
HPE is offline   Reply With Quote
Old   November 27, 2019, 18:16
Hi HPE, thanks for answering.
Perhaps it is intentionated, I mean, that the own OF only prevents the normal vector out with the slip condition.
I attached a picture that demonstrates it. There you will see the value of the velocity field vectors on the cylinder walls. They should be tangential but it seems that the slip condition simply removes the normal components pointing outwards.
Does anyone know if directionMixed can eliminate both the normal component pointing outwards and inwards?
Old   November 27, 2019, 23:12
HPE
HPE's Avatar
There is no way that 'slip' condition can introduce flow into the domain unless a setup or postprocessing issue.
Is there any chance for you to share your case minimally?
Old   November 28, 2019, 18:07
Here you have the case with the solver and the function for initial profile for B.
Thanks!,
David.
cylinderSmallBzSlip_ (3).zip
directionmixed bc, normal velocity, noslip, slip b.c.
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
How to set the velocity inlet boundary condition in the compressible flow? lienien FLUENT 2 March 11, 2013 08:25
