About the outer PIMPLE loop
Old   July 24, 2013, 11:53
Question About the outer PIMPLE loop
hz283 is on a distinguished road
Hi All,
I am recently doing a transient simulation using rhoPimpleFoam (version 2.1.1). There is a parameter called as nOuterCorrectors controlling the outer looping numbers. I have the following questions:
1, To do an accurate transient simulation, how many loops should I used? Because when just use one loop the simulation still can run but if I increase the loop to 5 iteration step, it still give some results. As an extreme example, when I increase the step to be 50, most of the later step need zZERO iteration step.
2, Is it necessary to make the outer looping convergent? and the corresponding standard for convengence? For example, when I increased the iteration step to be 50, can we think of those iterations with zero step as convengence? If yes, why does Openfoam not stop automatically to continue to the next time step? However, in another forum, I find the following thread:
http://www.openfoam.org/mantisbt/view.php?id=371
Where the outerloop will finish in advance (less than 50 steps). This situation never happens in my openfoam simulations.
Any comments and help are welcome, thanks.
hz283 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
CFX TASCflow - while-endwhile loop ina macro Deepak Ganga CFX 0 September 6, 2003 22:21
