Euler solver in BCs
I'm trying to implement a boundary conditions that links pressure to outflow using a differential equation (Windkessel) and therefore need to solve it. A simple 1st order backward Euler solver should be enough and, fortunately, one is available in OF. I've never added a new BC but I tried a take an existing one, use the outflow on the selected patch to calculate the pressure and export it. I was wondering : what it the best existing BC to start from ? Has anyone an example a the use of a solver in a BC function ? Best regards, Florian |
Dear Hiroshiman
The following pdf by Håkan Nilsson in Chalmers University is so helpful. How to implement a new boundary conditions: http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf Also, take a look at his homepage for more tutorials: http://www.tfd.chalmers.se/~hani/index.html http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/ |
Hi Kia,
thank you for the links. Actually I've already read the Chalmers guide for the programmation of BCs. Currently I'm using the codedFixedValue BC with a code that calculates p from phi on the outlet. I still have a few problems : how can I access the mean value of the pressure on the patch ? I'm able to do it for phi but not for p (surfaceField vs volume Field). Code:
const surfaceScalarField& phi = db().lookupObject<surfaceScalarField>("phi"); d(p-phi*R)/dt=f(p,phi) to impose p on the outlet, is it possible to use the ddt solver of openfoam ? I coded an Euler solver but I'd like to use a maximum of integrated functions... Regards, Florian |
Hiroshiman, did you manage to get it to work? Here is how you can access pressure. Code:
I am using resistance boundary conditions, where the pressure outlet is simply the product of a resistance value and the flowrate at the outlet. I have coded it with codedFixedValue but am not getting the same results as those I find in Fluent. Any pointers would be appreciated, Kind regards, Andreas |
HI, It's been a long time, but has anyone solved this problem? I should be doing the exact same thing.
Thanks! |
