Where are correct () and update() functions defined ?
Like Tree1Likes
  • 1 Post By dkxls
Old   July 24, 2013, 10:14
Default Where are correct () and update() functions defined ?
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Foamers,
I am focusing the codes of sonicTurbDyMEngineFoam these days.
Do you know where is the correct() function defined in below code ?
 thermo.correct();
And where is update() function defined in below code ?
 bool meshChanged = mesh.update();
I appreciate your help.
Thanks and best regards,
Sasan.
P.S. correct function declared as a pure virtual function in basicThermo class.
sasanghomi is offline   Reply With Quote
Old   July 24, 2013, 11:00
Haomin Yuan
yhaomin2007 is on a distinguished road
For the first question "thermo.correct();"
It depends on what thermo model you are using. Take hPsiThermo as an example.
It is define in
/src/thermophysicalModels/basic/psiThermo/hPsiThermo/hPsiThermo.C
For the second question. This is used dynamic meshing.It also depends on what dynamic meshing utility you are using. If you use dynamicRefineFvMesh
It is defined in
/src/dynamicFvMesh/dynamicRefineFvMesh/dynamicRefineFvMesh.C
yhaomin2007 is offline   Reply With Quote
Old   July 24, 2013, 11:44
Sasan Ghomi
Dear Haomin
Thank you very much.
Best regards
Sasan.
Old   August 15, 2013, 15:04
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Sasan,Haomin and other dears
what does correct() do on thermo type?
I can't find thermo.correct() in the library below:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011-2012 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "hePsiThermo.H"
// * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
template<class BasicPsiThermo, class MixtureType>
void Foam::hePsiThermo<BasicPsiThermo, MixtureType>::calculate()
    const scalarField& hCells = this->he_.internalField();
    const scalarField& pCells = this->p_.internalField();
    scalarField& TCells = this->T_.internalField();
    scalarField& psiCells = this->psi_.internalField();
    scalarField& muCells = this->mu_.internalField();
    scalarField& alphaCells = this->alpha_.internalField();
    forAll(TCells, celli)
        const typename MixtureType::thermoType& mixture_ =
            this->cellMixture(celli);
        TCells[celli] = mixture_.THE
            hCells[celli],
            pCells[celli],
            TCells[celli]
        psiCells[celli] = mixture_.psi(pCells[celli], TCells[celli]);
        muCells[celli] = mixture_.mu(pCells[celli], TCells[celli]);
        alphaCells[celli] = mixture_.alphah(pCells[celli], TCells[celli]);
    forAll(this->T_.boundaryField(), patchi)
        fvPatchScalarField& pp = this->p_.boundaryField()[patchi];
        fvPatchScalarField& pT = this->T_.boundaryField()[patchi];
        fvPatchScalarField& ppsi = this->psi_.boundaryField()[patchi];
        fvPatchScalarField& ph = this->he_.boundaryField()[patchi];
        fvPatchScalarField& pmu = this->mu_.boundaryField()[patchi];
        fvPatchScalarField& palpha = this->alpha_.boundaryField()[patchi];
        if (pT.fixesValue())
            forAll(pT, facei)
                    this->patchFaceMixture(patchi, facei);
                ph[facei] = mixture_.HE(pp[facei], pT[facei]);
                ppsi[facei] = mixture_.psi(pp[facei], pT[facei]);
                pmu[facei] = mixture_.mu(pp[facei], pT[facei]);
                palpha[facei] = mixture_.alphah(pp[facei], pT[facei]);
        else
            forAll(pT, facei)
                pT[facei] = mixture_.THE(ph[facei], pp[facei], pT[facei]);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::hePsiThermo<BasicPsiThermo, MixtureType>::hePsiThermo
    const fvMesh& mesh,
    const word& phaseName
    heThermo<BasicPsiThermo, MixtureType>(mesh, phaseName)
    calculate();
    // Switch on saving old time
    this->psi_.oldTime();
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::hePsiThermo<BasicPsiThermo, MixtureType>::~hePsiThermo()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
void Foam::hePsiThermo<BasicPsiThermo, MixtureType>::correct()
    if (debug)
        Info<< "entering hePsiThermo<BasicPsiThermo, MixtureType>::correct()"
            << endl;
    // force the saving of the old-time values
    calculate();
    if (debug)
        Info<< "exiting hePsiThermo<BasicPsiThermo, MixtureType>::correct()"
            << endl;
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 15, 2013, 15:06
Haomin Yuan
It calculate other properties from pressure and h or e.
Old   August 16, 2013, 09:49
dkxls's Avatar
Armin
dkxls will become famous soon enough
thermo.correct() is just a wrapper for thermo.calculate(). See the code below for an example.
This has been discussed here already some time ago, search the forum and you will find more information.
    if (debug)
            << endl;
    calculate();
    if (debug)
            << endl;
mikulo likes this.
dkxls is offline   Reply With Quote
Is my Dynamic mesh setup correct? cfd seeker FLUENT 16 October 30, 2020 06:16
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
apt-get update Duplicate lists of OpenFOAM Xulia OpenFOAM Installation 2 June 20, 2013 10:13
Using Workbench, CFX-Pre doesn't update mesh from upstream data Shawn_A CFX 2 November 25, 2012 13:06
how can I correct the udf? happyrabbit FLUENT 9 January 28, 2011 09:50
