set Min and Max values for pressure in pimpleFoam
Like Tree2Likes
  • 2 Post By Bernhard
Old   September 2, 2013, 17:57
Default set Min and Max values for pressure in pimpleFoam
mechy is on a distinguished road
Hi all
in my problem the velocities are calculated correctly but pressure is not.
I use pimpleFoam and I want to limit the pressure
I add bellow statment in fvSolution/PIMPLE
pMin pMin [ 0 2 -2 0 0 0 0 ] -150;
pMax pMax [ 0 2 -2 0 0 0 0 ] 150;
but it not work
any help will be appreciated
mechy is offline   Reply With Quote
Old   September 3, 2013, 00:13
Nima Samkhaniani
nimasam is on a distinguished road
Hello
did you change your solver at all!? then those lines would not reflect anything to solver
besides as you use incopressible solver i dont gauss its a good idea to limit the pressure which will be effect on continuity too and it may impair divergence issue
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 3, 2013, 01:05
Hi Nima
I have added the setting of my test case as follow:
more information:
I use my icoFsiFoam solver which used pimpleFoam for solve fluid.
the results is good until time=0.1205 with maxCor=.6 ( deltaT ~1e-5)
at the next state (Time = 0.1205+deltaT) the velocity is calculated correctly, but pressure not.
I check the original pimpleFoam solver to solve fluid only, but the pressure is diverged again. I have attached its contours.
fvSchemes
HTML Code:
ddtSchemes
    default Euler;
gradSchemes
    default           Gauss linear ;//cellMDLimited leastSquares 1;//extendedLeastSquares 1;
//    grad(p)         leastSquares ;
//    grad(U)         leastSquares ;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinearV 1;//Gauss linearUpwindV grad(U);//
    div(phi,k)      Gauss upwind;//limitedLinear 1;
    div(phi,omega)  Gauss upwind;//limitedLinear 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
     div((nuEff*dev(grad(U).T())))  Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;//Gauss linear limited 0.5;//
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    pcorr           ;
    p;
fvSolutions
HTML Code:
solvers
    p
        solver           GAMG;
        tolerance        1e-4;
        relTol           0;
        smoother         GaussSeidel;
        nPreSweeps       1;
        nPostSweeps      2;
        cacheAgglomeration true;
        directSolveCoarsest true;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 40;
        mergeLevels      1;
        minIter          1;
    pFinal
        solver           GAMG;
        tolerance        1e-8;
        relTol           0;
        nPreSweeps       1;
        nPostSweeps      2;
        mergeLevels      1;
        minIter          1;
    "(U|k|omega)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance        1e-5;
        relTol           0;
        nSweeps          1;
        minIter          1;
    "(UFinal|kFinal|omegaFinal)"
        solver           smoothSolver;
        tolerance        1e-6;
        relTol           0.0;
        nSweeps          1;
        minIter          1;
PIMPLE
    nOuterCorrectors    3;
    nCorrectors         2;
    nNonOrthogonalCorrectors 3;
    pRefCell            0;
    pRefValue           0;
//    momentumPredictor yes;
    ddtPhiCorr no;
    correctPhi no;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        omega           0.7;
cache
    grad(U);
Old   September 3, 2013, 02:24
Bernhard
Bernhard is on a distinguished road
Bounding pressure is certainly not the way to go. Check your velocity in a few more time steps, and you will probably see something weird there as well. In other words, your solution is diverging, please check the residuals of the equations from the log file. It might be wise to study the origin of the pressure issue, which might well be related to the FSI part.
nimasam and FrankFlow like this.
Bernhard is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Turbo contours Max n Min Values Sans CFX 2 May 31, 2008 04:22
