adding tetDecompositionMotionSolver and tetDecompositionFiniteElement to OF 2.2 |
August 20, 2013, 09:39 |
Rep Power: 14 |
Hi all
I want to add tetDecompositionFiniteElement classes to OF2.2 and then add the tetDecompositionMotionSolver for moving mesh at first I copied the decompositionMethods folder in src of OF 2.2 but I can not compile it any help will be appreciated |
August 20, 2013, 13:55 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Mechy,
First of all, you will need to add a lot more information, such as the error message from the compilation. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
August 21, 2013, 09:05 |
#3 | |
Rep Power: 14 |
Hi Niels thanks so much for your answer can you give me more information ? can you locate those information in OF-1.6ext folder ? Best Regards |
August 21, 2013, 09:35 |
Rep Power: 37 |
You say that you cannot compile the library. This would mean that you get error messages. Put those in a file and attach them to a post. Without the error messages, nobody will be able to help you.
A step-by-step description of what you have been doing is also beneficial. Kind regards Niels
Boundary condition setting for adding gravity in simpleFoam | norkistar | OpenFOAM Programming & Development | 3 | June 15, 2022 04:20 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Problem creating a new Wallfunction on OF 2.2 ! | fredo490 | OpenFOAM Programming & Development | 8 | July 22, 2014 05:16 |
car Cd drops after adding inlet and outlet? | wh88 | FLUENT | 0 | October 19, 2011 13:23 |
Help with chtMultiRegionFoam | jbvw96 | OpenFOAM Running, Solving & CFD | 2 | December 26, 2010 17:16 |
