start Runner from python with machinefile
Hello everyone,
I have a small issue with pyFoam: I wrote a script for my local machine and it uses this to call the solver Code:
machine=LAMMachine(nr=no_proc) I tried the following: Code:
machine=LAMMachine(machines=nodefile,nr=no_proc) Code:
run_str="mpirun -hostfile "+nodefile+" -np "+str(no_proc)+" "+ solver +" -case "+work.name+ " -parallel &> solver."+outputName_nospc+".log" Any suggestions on how to setup the correct call for pyFoamRunner will be appreciated :) Thanks in advance, Arne |
Additional questions: Does the parallel script work on the local machine? Is the Distro on the local machine the same as on the cluster? Are you from Ireland (answer only required in case of the Lepreachauns)? See slide 53 and following of http://openfoamwiki.net/images/8/84/...ining_OFW8.pdf and try to set Code:
[Debug] |
