Time Dependent BC Problem
Old   September 19, 2013, 10:22
Default Time Dependent BC Problem
eRzBeNgEl is on a distinguished road
Hi guys,
I am trying to implement a time depending velocity inlet
Here is my U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
in
type uniformFixedValue;
uniformValue table
(0 (1 0 0))
(30 (1000 0 0))
(35 (1 0 0))
out
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (1 0 0);
.......and so on..........
And this is the error message@Output
Time = 0.0002
Courant Number mean: 4.24553e-06 max: 5.5807e-05
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.02838e-11, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM FATAL ERROR:
Attempt to cast type uniformFixedValue to type freestream
From function refCast<To>(From&)
in file /opt/openfoam221/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
What am I doing wrong here? I do not get my mistake?
I am using OF v221
Thanks for help
eRzBeNgEl is offline   Reply With Quote
Old   September 23, 2013, 07:02
No one has got an idea about this?
Old   September 23, 2013, 07:25
Sasan Ghomi
sasanghomi is on a distinguished road
Try to use this type :
in
type timeVaryingUniformFixedValue;
fileName "ramp.dat";
outOfBounds clamp;
Now you should create a ramp.dat file in your case directory like this :
(0 (1 0 0 ))
(1 (2 0 0 ))
(3 (3 0 0 ))
hope this helps.
sasanghomi is offline   Reply With Quote
Old   September 23, 2013, 09:28
outOfBounds clamp;
Thanks for your reply, but this BC does not exist for OpenFoam v221.
I am still having this problem. Any suggestion?
Old   September 24, 2013, 07:25
Sasan Ghomi
This boundary condition exists in OP 210 and 1.6-ext . Are you sure this BC doesn't exist in 221 ? try to use xxx instead of type of boundary condition and after running you will get an error that in this error you can see all BC in version 221 . After that paste all types of BC here.
Old   September 24, 2013, 11:21
I solved my problem:
OF v221 BCs are listed here:
http://www.openfoam.org/version2.1.0...conditions.php
It says that
type timeVaryingUniformFixedValue are now part of
The BCs that include time-varying options in v2.1.0 are:
flowRateInletVelocity: inlet condition with time-varying flow-rate.
oscillatingFixedValue: oscillatory fixed value condition with time-varying amplitude and frequency.
rotatingPressureInletOutletVelocity: total pressure condition for a rotating patch with time-varying angular velocity.
rotatingTotalPressure: total pressure condition for a rotating patch with time-varying angular velocity.
rotatingWallVelocity: velocity condition for a rotating boundary, e.g. a wheel, with time-varying angular velocity.
uniformFixedValue: general fixed value condition with time-varying value.
uniformTotalPressure: total pressure condition with time-varying pressure.
And my problem:
I thought I also changed my pressure conditions. In a further version I had freestreamPressure as BC. Somehow I did not saved the edited Pressure file. Just had to change the boundarys to fixedValue, zeroGradient, eg.. and it worked fine.
Thanks for your help
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
[stressAnalysis] Residual plot for OpenFOAM-ext problem. Sargam05 OpenFOAM CC Toolkits for Fluid-Structure Interaction 26 July 14, 2014 08:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
