How to define a sliding wall BC in OpenFOAM??? |
September 15, 2013, 23:14 |
Anonymous
Rep Power: 12 |
I am new to OpenFOAM. My case is to simulate lamb-oseen vortex in a Cuboid shaped domain. I have given a fixed value for my 'Inlet' , outletInlet for 'Outlet' and wall Bc for the bottom face. I have to give 'Sliding wall" BC to other three faces. Algorithm: PISO Turbulence model : LES What does this sliding wall numerically means and how should I implement it in OpenFOAM??? what should I give for U, P, k and nuTilda? |
September 17, 2013, 09:13 |
David GISEN
Hi Hi123,
maybe the sliding wall in http://www.openfoam.org/docs/user/cavity.php#x5-40002.1 is enough for you? Very simple. You can set the turbulent variables to zeroGradient at the wall(s), the others like in the tutorial. Regards, David |
September 24, 2013, 22:03 |
Anonymous
Rep Power: 12 |
Thanks alot.. and I have one more doubt..
I need to initialise lamb-oseen vortex in my domain..I have the u,v,w component equations in cartesian co-ordinates for velocity at time t=0. 1. How can I give a non-uniform velocity profile ? 2. If I can use FunkySetFields, Can anyone please tell me how to use it..? 3. I also have a c coding that generates the required velocity values at every node for my domain, used for FLUENT. Is it possible to use the same coding in OpenFOAM ??? |
[Commercial meshers] Exporting to OpenFOAM mesh with "inner" wall region | raagh77 | OpenFOAM Meshing & Mesh Conversion | 0 | April 24, 2012 06:23 |
Radiative equilibrium wall condition in OpenFOAM | JLight | OpenFOAM | 0 | September 11, 2011 23:31 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 04:36 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
