September 20, 2013, 03:51 |
exponentially decaying boundary condition
Sean McGinty
Rep Power: 12 |
I'm considering a simple diffusion problem using laplacianFoam and trying to add a simple boundary condition that decays exponentially with time, something like exp(-A*t), where A is some constant and t is time. My problem is concerned with the concentration, C, of some drug and so I have modified the standard laplacianFoam code to `C' rather than `T'.
Firstly, can anyone advise me how to set this up so that foam computes the boundary condition value at each new timestep? Secondly, as a quick-fix attempt, I looked at http://www.openfoam.org/version2.1.0...conditions.php and tried to do this by tabulating some values. My "C" file in the "0" folder looks like: FoamFile { version 2.0; format ascii; class volScalarField; object C; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 -3 0 0 1 0 0]; internalField uniform 0; boundaryField { impermeable { type zeroGradient; } source { type uniformFixedValue; uniformValue table ( (0 1) (360 0.3) ); } defaultFaces { type empty; } } Presumably the tabulation means that at time t=0 the value is 1 and at time 360 the value is 0.3? although this isn't clear at all from the link above. What value is taken at other times? Anyway, the code seems to run, but I cannot view it in paraFoam - the error is "ERROR: In /builddir/build/BUILD/ParaView-3.8.1/VTK/IO/vtkOpenFOAMReader.cxx, line 6349 vtkOpenFOAMReaderPrivate (0x3af1990): Wrong list type for uniform field " I'm not sure if this a a problem with my code or simply the paraview. Any help much appreciated |
September 20, 2013, 04:49 |
Mohammad Shakil Ahmmed
Rep Power: 14 |
Have tried with groovyBC: http://openfoamwiki.net/index.php/Contrib_groovyBC |
October 22, 2013, 00:31 |
Jakob Hærvig
Rep Power: 13 |
Did you manage to solve this problem?
I am having the same problem |
October 28, 2013, 04:06 |
Sean McGinty
Rep Power: 12 |
Yes, groovyBC did the job
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
