error in run interFoam
Old   November 3, 2013, 00:53
Default error in run interFoam
abdollahi
abdollahi is on a distinguished road
what is error ????????????
/bin/sh: module: line 1: syntax error: unexpected end of file
/bin/sh: error importing function definition for `module'
/usr/bin/cr_run: /opt/gridengine/default/spool/amd-9-1/job_scripts/27943: /bin/sh^M: bad interpreter: No such file or directory
/usr/bin/cr_run: line 61: /opt/gridengine/default/spool/amd-9-1/job_scripts/27943: Success
/bin/bash: module: line 1: syntax error: unexpected end of file
/bin/bash: error importing function definition for `module'
abdollahi is offline   Reply With Quote
Old   November 3, 2013, 05:56
Retired Super Moderator
Bruno Santos
Greetings abdollahi,
If you don't provide more information, all I can say is that the error is this:
Best regards,
Bruno
Old   November 3, 2013, 07:09
Default error run interFoam with 40 cores
abdollahi
run with system have 40 cores.but with one core, not found error.
error:
/usr/bin/cr_run: /opt/gridengine/default/spool/gpu-4-1/job_scripts/28374: /bin/sh^M: bad interpreter: No such file or directory
/usr/bin/cr_run: line 61: /opt/gridengine/default/spool/gpu-4-1/job_scripts/28374: Success
Old   November 3, 2013, 10:02
Nima Samkhaniani
nimasam is on a distinguished road
it returns to the bash script you run,
could you post it here?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Use sampled data from previous run as boundary condition for new setup Arnoldinho OpenFOAM Running, Solving & CFD 3 December 6, 2012 13:16
crash:parallel run and writetime? calim_cfd OpenFOAM Bugs 2 March 5, 2012 19:13
What's the best order to run this simulation in? siw CFX 1 November 4, 2009 19:42
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
