Steady-State Transient solvers for miscible fluids |
December 3, 2013, 04:22 |
Faraj
Rep Power: 16 |
Hi everybody,
I am kinda new to openFOAM, and I have a lot of questions. I thought it would be appropriate to ask them here. I don't understand why there is no Steady state solvers for transient solvers with mixing/miscible fluids in OpenFOAM. Is it not logical to make such a solver? |
December 3, 2013, 05:42 |
Lieven
Rep Power: 22 |
Hi Filankes,
Could you clarify a bit what you mean with "steady state solvers" for "transient solvers"? (Not sure if this is what you mean: ) In principle every transient solver could be used as a steady state solver by setting the ddt-schemes in fvSchemes to steadyState. But it should be noted that "an application designed for transient problems will not necessarily run as steady-state and visa versa" as mentioned at http://www.openfoam.org/docs/user/fvSchemes.php Cheers, L |
January 29, 2014, 17:47 |
Faraj
Rep Power: 16 |
Thanks Liven, I;ll experiment it, and tell my experiences.
Thanks again. |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
time step and iterations in steady state problem using transient solver | jing113cn | FLUENT | 2 | January 15, 2010 03:18 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
