How to exert a moving heat source on a plate? |
February 21, 2014, 10:08 |
wumin
Rep Power: 12 |
hello,
I'm new to OpenFoam and have a questions about how to exert a moving heat source on a plate? It would be great if someone could help me! Greetings wumin |
February 23, 2014, 22:48 |
Mohammad Shakil Ahmmed
There are two ways to do that. First, you can consider the heat source is fixed and the material underneath it is moving. This is called fixed co-ordinate system, and this method is good in terms of computational cost.
Second, is the moving co-ordinate system i.e. heat source is moving and work-piece is fixed. Let, you want to impose a surface heat source. Then the easiest way is to first install groovyBC (which comes with swak4Foam http://openfoamwiki.net/index.php/Contrib/swak4Foam). Then for, First method (fixed co-ordinate): imposed as boundary condition this can be done by imposing groovyBC boundary condition easily. Code:
type groovyBC; variables "Q;K;"; gradientExpression "Q/K"; fractionExpression "0"; Second methodmoving co-ordinate) Code:
type groovyBC; variables "Q;K;v;"; gradientExpression "(Q/K)*(pos().x-v*time())"; //just for example fractionExpression "0"; cheers, #shakil |
February 24, 2014, 04:12 |
wumin
Rep Power: 12 |
Hi,shakil
Thanks for your reply and contribution.I have installed groovyBC successfully. My work is mainly to simulate the melting and solidification of selective laser melting(3D printing) ,similar to the laser welding.Do you have some related case of OpenFoam application? Thank you very much for your help! |
February 24, 2014, 07:05 |
Hi Wumin,
wow great! I'm working on the similar type of project. I'm working on melting and solidification of Si under laser. Have write anything for that? For melting/solidification you can take help from: http://www.cfd-online.com/Forums/ope...g-problem.html cheers, #shakil |
February 24, 2014, 07:38 |
wumin
Rep Power: 12 |
Hi shakil,
You are my savior!!I have spent a lot of time on how to exert a moving heat source on a plate.You provide me a solution to this problem.Do you use the method of groovyBC to solve this problem? or another method? Greetings , wumin |
February 24, 2014, 08:17 |
For implementing laser heat source, I used as explained. For melting problem you can easily picked up the code from http://www.cfd-online.com/Forums/ope...g-problem.html here. That's it. cheers, #shakil |
May 7, 2014, 10:35 |
Do we need to specify a moving group
Sushanta Sahu
Dear Shakil and Wumin,
I am also working on Laser welding of Cu/Steel flats and pipes and want to simulate the process in OpenFOAM. My doubt is whether we need to specify a moving group on the face to accept the radiative heat from the laser source. I am creating the mesh in salome-meca v2013.1. Till now I have created a mesh for the plates attached in butt fashion. Defined some groups of solids for dissimilar metals, some faces for BC. But the doubt is how to give the periodic flux to the surface at the interface. |
December 8, 2016, 02:24 |
#8 | |
Hi i am currently doing laser melting too. Do you have any guide or templates which i can learn from? Regards, Jay |
November 26, 2018, 09:00 |
Christian Lackner
Hello your two,
I have the same problem, however I can not implement it right. I always get the error code "Cannot find 'value' entry on patch up of field T in file... ... which is requiered to set the value of the generic patch field. (Actual type groovyBC) Can someone please tell me what i am most likely doing wrong when i get this error? PS: I already have written libs("libgroovyBC.so") in the ControlDict, so its not because of that. |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 05:07 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
