Different fluids, question
I need to simulate a case where air and two more fluids (gas state too) interact cause convection movements. The good point is that these fluids do not react among themselves. I am a totally beginner in OpenFoam but I have the user manual and I am learning from there and examples and tutorials that I can find on internet. My question is: Do I need a multiphase solver for my case? Cause I am not sure if multiphase means more fluids or different states of the same fluid (liquid and gas). So, if it is not multiphase, then which solver would you recomend me? Or which kind of solvers? And finally, Do you have tutorials for this solver? Or do you know where I can find them? wating for your answers Thank you very much, :D |
I believe in your case it is multiphase flow. I also just started to simulate multiphase flow and I suggest you starting from 'interFoam' (or 'compressibleInterFoam' if it's compressible). You can find those examples in the tutorial folders. As a starter I found it confusing to read some tutorials because they don't have much comments and explanations. So I think you need to be patient. Best, |
Nevermind, the interFoam has the breaking of a dam tutorial explained on the user guide, so I will focus on this one! Thanks a lot |
If you had only two fluids you might be able to use twoLiquidMixingFoam. Have a look at the implementation of the solver and check if you can extend it to use three fluids.
Maybe explain the problem you're trying to simulate in more detail? Regards, |
