August 18, 2014, 05:19 |
pimpleDymFoam for tidal turbine
chen long
Rep Power: 13 |
Hi
I try to simulate the flow around tidal turbines by using pimpleDyMFoam. however, the simulation stopped right after i executing the "Allrun" command. The msg in the log file are shown as below, anyone know the reason? Thanks // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone innercylinder Reading field p Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 2660 source faces and 2660 target faces AMI: Patch source weights min/max/average = 4.83927e-09, 1.00063, 0.834913 AMI: Patch target weights min/max/average = 0, 1.20756, 0.834843 Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading field rAU if present No field sources present PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Starting time loop Courant Number mean: 9.59912e-05 max: 0.0060191 deltaT = 1.1999e-05 Time = 1.1999e-05 solidBodyMotionFunctions::rotatingMotion::transfor mation(): Time = 1.1999e-05 transformation: ((0 0 0) (1 (0 -5.02615e-05 0))) AMI: Creating addressing and weights between 2660 source faces and 2660 target faces AMI: Patch source weights min/max/average = 1.91434e-05, 1.21386, 0.961821 AMI: Patch target weights min/max/average = 0, 1.24578, 0.960982 PIMPLE: iteration 1 [1] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" [1] #5 [1] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" [1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #7 [1] in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" [ubuntu:05018] *** Process received signal *** [ubuntu:05018] Signal: Floating point exception (8) [ubuntu:05018] Signal code: (-6) [ubuntu:05018] Failing at address: 0x3e80000139a [ubuntu:05018] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f15e79524a0] [ubuntu:05018] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f15e7952425] [ubuntu:05018] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f15e79524a0] [ubuntu:05018] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKdRK NS_5UListIdEE+0x24) [0x7f15e8aa2754] [ubuntu:05018] [ 4] pimpleDyMFoam(_ZN4FoamdvINS_12fvPatchFieldENS_7vol MeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKNS_ 11dimensionedIdEERKS8_+0x2a0) [0x43e180] [ubuntu:05018] [ 5] pimpleDyMFoam() [0x4186cb] [ubuntu:05018] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f15e793d76d] [ubuntu:05018] [ 7] pimpleDyMFoam() [0x41c38d] [ubuntu:05018] *** End of error message *** |
August 18, 2014, 06:30 |
Andre Weiner
Rep Power: 13 |
The solver crashes because some weights are zero.
AMI: Patch source weights min/max/average = 1.91434e-05, 1.21386, 0.961821 AMI: Patch target weights min/max/average = 0, 1.24578, 0.960982 Code:
AMIPatch { type cyclicAMI; ... lowWeightCorrection 0.2; } so maybe you should improve the mesh quality first. Best regards! |
August 18, 2014, 08:13 |
chen long
Rep Power: 13 |
Andre
Thanks a lot. Normally how you improve the quality of mesh? |
August 18, 2014, 08:33 |
Andre Weiner
Rep Power: 13 |
A better mesh quality regarding to AMI faces in OF you achieve e.g. with :
- a better approximation of your geometry - AMI cell faces of the same shape and size How you accomplish this depends on your meshing tool. |
August 18, 2014, 08:41 |
chen long
Rep Power: 13 |
Andre
what meshing tool are you using? Best regards |
August 18, 2014, 08:47 |
Andre Weiner
Rep Power: 13 |
That pretty much depends on the available resources :-)
You can use snappyHexMesh like in the propeller tutorial cd $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/propeller/ |
August 18, 2014, 11:09 |
chen long
Rep Power: 13 |
Andre
My case is based on thsi tutorial. M using snappyhexmesh utility, but i only simple execute the command dunno how to set the details to control the quality of the mesh. May be i need to understand the snappyhexMeshDict so that i can produce more quality mesh of my turbine. |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
Wind Turbine from SRFSimpleFoam to pimpleDymFoam | be_inspired | OpenFOAM | 3 | March 11, 2015 10:58 |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
simulating a wind turbine | s.q | FLUENT | 1 | October 17, 2013 08:11 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
