foam-extend_3.1 decompose and pyfoam warning
Old   July 23, 2014, 02:25
Default foam-extend_3.1 decompose and pyfoam warning
Baris (Heewa)
shipman is on a distinguished road
Hi to everybody,
I am using foam-extend 3.1 and ubuntu version 12.04. After installation 3.1, when i tried to decompose my case although it gives following warning it makes decomposition:
HTML Code:
Create mesh for region region0
Calculating distribution of cells
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 85
    could not load libmetisDecomp.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function decompositionMethod::loadExternalLibraries()
    in file decompositionMethod/decompositionMethod.C at line 453
    Loading of decomposition library libmetisDecomp.so unsuccesful. Some decomposition methods may not be  available
--> FOAM Warning :
    could not load libparMetisDecomp.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    Loading of decomposition library libparMetisDecomp.so unsuccesful. Some decomposition methods may not be  available
Selecting decompositionMethod simple
Finished decomposition in 0.25 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 11668
    Number of faces shared with processor 1 = 11850
    Number of faces shared with processor 4 = 104
    Number of processor patches = 2
    Number of processor faces = 11954
    Number of boundary faces = 11898
Processor 1
    Number of cells = 20171
    Number of faces shared with processor 0 = 11850
    Number of faces shared with processor 2 = 1605
    Number of faces shared with processor 5 = 296
    Number of processor patches = 3
    Number of processor faces = 13751
    Number of boundary faces = 2282
Processor 2
    Number of cells = 16737
    Number of faces shared with processor 1 = 1605
    Number of faces shared with processor 3 = 1190
    Number of faces shared with processor 6 = 263
    Number of faces shared with processor 5 = 22
    Number of faces shared with processor 7 = 6
    Number of processor patches = 5
    Number of processor faces = 3086
    Number of boundary faces = 6942
Processor 3
    Number of cells = 16510
    Number of faces shared with processor 2 = 1190
    Number of faces shared with processor 7 = 348
    Number of processor faces = 1538
    Number of boundary faces = 6888
Processor 4
    Number of cells = 13049
    Number of faces shared with processor 5 = 11874
    Number of faces shared with processor 0 = 104
    Number of faces shared with processor 8 = 155
    Number of processor faces = 12133
    Number of boundary faces = 12051
Processor 5
    Number of cells = 19115
    Number of faces shared with processor 4 = 11874
    Number of faces shared with processor 1 = 296
    Number of faces shared with processor 6 = 1559
    Number of faces shared with processor 2 = 22
    Number of faces shared with processor 9 = 232
    Number of faces shared with processor 8 = 50
    Number of processor patches = 6
    Number of processor faces = 14033
    Number of boundary faces = 2193
Processor 6
    Number of cells = 16566
    Number of faces shared with processor 5 = 1559
    Number of faces shared with processor 2 = 263
    Number of faces shared with processor 7 = 1157
    Number of faces shared with processor 10 = 242
    Number of faces shared with processor 9 = 1
    Number of faces shared with processor 11 = 3
    Number of processor faces = 3225
    Number of boundary faces = 6844
Processor 7
    Number of cells = 16356
    Number of faces shared with processor 3 = 348
    Number of faces shared with processor 6 = 1157
    Number of faces shared with processor 2 = 6
    Number of faces shared with processor 11 = 320
    Number of processor patches = 4
    Number of processor faces = 1831
    Number of boundary faces = 6795
Processor 8
    Number of cells = 24098
    Number of faces shared with processor 4 = 155
    Number of faces shared with processor 9 = 10882
    Number of faces shared with processor 5 = 50
    Number of faces shared with processor 10 = 102
    Number of processor faces = 11189
    Number of boundary faces = 13084
Processor 9
    Number of cells = 9528
    Number of faces shared with processor 8 = 10882
    Number of faces shared with processor 5 = 232
    Number of faces shared with processor 10 = 1626
    Number of processor faces = 12741
    Number of boundary faces = 1943
Processor 10
    Number of cells = 15511
    Number of faces shared with processor 6 = 242
    Number of faces shared with processor 9 = 1626
    Number of faces shared with processor 11 = 1318
    Number of faces shared with processor 8 = 102
    Number of processor faces = 3288
    Number of boundary faces = 6414
Processor 11
    Number of cells = 15948
    Number of faces shared with processor 7 = 320
    Number of faces shared with processor 10 = 1318
    Number of faces shared with processor 6 = 3
    Number of processor faces = 1641
Number of processor faces = 45205
Max number of processor patches = 6
Max number of faces between processors = 14033
Processor 0: field transfer
Processor 1: field transfer
Processor 2: field transfer
Processor 3: field transfer
Processor 4: field transfer
Processor 5: field transfer
Processor 6: field transfer
Processor 7: field transfer
Processor 8: field transfer
Processor 9: field transfer
Processor 10: field transfer
Processor 11: field transfer
End.
Then to check this warning i run the foamIstallation and it gives following error:
HTML Code:
Executing /home/baris/foam/foam-extend-3.1/bin/foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               baris-desktop
OS:                 Linux version 3.2.0-29-generic
Checking main foam-extend env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/baris/foam                         yes       yes
$WM_PROJECT_USER_DIR /home/baris/foam/baris-3.1               no        no
$WM_THIRD_PARTY_DIR  ...aris/foam/foam-extend-3.1/ThirdParty  yes       yes
Checking the foam-extend env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/baris/foam/foam-extend-3.1         yes  yes  yes
$FOAM_APPBIN         ...3.1/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...is/foam/site/3.1/bin/linux64GccDPOpt  yes  yes  no
$FOAM_USER_APPBIN    ...3.1/applications/bin/linux64GccDPOpt  no        no
$WM_DIR              /home/baris/foam/foam-extend-3.1/wmake   yes  yes  yes
Checking the foam-extend env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         .../foam-extend-3.1/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...is/foam/site/3.1/lib/linux64GccDPOpt  yes  yes  no
$FOAM_USER_LIBBIN    ...s/foam/baris-3.1/lib/linux64GccDPOpt  no        no
$MPI_ARCH_PATH       ...nmpi-1.6.5/platforms/linux64GccDPOpt  yes  yes  yes
Third party software
Software Version   Location
WARNING: gcc version does not match gcc supplied with this release of foam-extend
         Supplied version: 4.3.3
         User version    : 4.6.3
         Minimum required: 4.3.1
gcc      4.6.3
WARNING:  Conflicting installations:
          foam-extend settings        : /bin/gcc
          current path             : /usr/bin/gcc
          CRITICAL ERROR
gzip     1.4       /bin/gzip
tar      1.26      /bin/tar
icoFoam            ...am-extend-3.1/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Could someone help to me how can i correct this error?
On the other hand, when i also tried to run parallel by using pyfoam it gives attached warning, but it is going to run. I am a bit confused about it. So, also about this if someone have idea i will be appreciated.
thanks a lot.
B
shipman is offline   Reply With Quote
Old   July 23, 2014, 16:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by shipman View Post
Hi to everybody,
HTML Code:
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
thanks a lot.
B
Have a look at your output: it is only a warning and says
Seems like metis and parMetis from the ThirdParty-directory did not compile correctly and therefor these decomposition methods were not compiled. But this doesn't concern you as you're using simple.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 24, 2014, 03:28
Baris (Heewa)
Hi Bernhard,
Thank you for the information. Could you also tell me how can i correctly compile the metis and parMetis from the ThirdParty-directory.
Also, do you have any idea about my 2nd (after runing the foamIstallation and it gives error) and 3rd (pyfoam warning) problems?
Thanks in advance.
Baris
Old   July 24, 2014, 08:14
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
I'll have to ask you to look elsewhere
a) I have no information whatsoever about your system
b) most probably somebody else already had the problem. Search the Board
c) my time is limited and I currently focus on swak4foam and pyFoam because I think there are few people here on the board with my expertise on these two. Installation-issues there are more people
Same for your second question.
Third question: please don't post screenshots of terminal output. It is hard to read and it is not searchable. From the blury pixels it looks like it is only a warning. Basically it found a string, tried to interpret it as a number and fails. Instead of failing it just informed you. To get to the heart of the matter I'd have to type it from your screenshot, hope that I didn't misstype it and try on my machine. Which I refuse to do. See c) above (first 4 words)
