heat conduction
Old   July 24, 2014, 12:26
Default heat conduction
Ahmed
asayed is on a distinguished road
hello friends,
I am new to openfoam. I want to solve transient heat conduction in composite wall (two material thermal properties) with mixed boundary condition (Transient model).
any help?
thanks
asayed is offline   Reply With Quote
Old   July 25, 2014, 12:04
Mohammad Shakil Ahmmed
ahmmedshakil is on a distinguished road
You can try with : chtMultiRegionFoam
ahmmedshakil is offline   Reply With Quote
Old   July 25, 2014, 13:53
Ahmed
but can chtMultiRegion solve convection boundary without introducing the fluid in the model??
and, do you ve a solved problem on this solver for solid regions only?
thanks
Old   July 27, 2014, 06:38
You can impose the convection boundary condition by using groovyBC easily. For using the chtMultiRegionFoam for solid heat transfers only, you can switch off the momentum equation.
Cheers,
#shakil
Old   July 31, 2014, 11:58
Ahmed
thank you Sir
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Conduction heat not balanced? Nepal CFX 7 May 31, 2005 11:51
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
