Porosity model not found for pisoFoam; works fine for simpleFoam
Hello all. I have a DES solution I am running using pisoFoam, in which I get the following error:
--> FOAM Warning : Are porous media not supported by pisoFoam? Or does the inclusion of porous forces simply not work with pisoFoam? |
Greetings to all!
ssss' solution should work. But to answer to another part of aerogt3's question: pisoFoam in OpenFOAM 2.3 and 2.2 was not modified to include support for the "fvOptions" feature. The closest solver you can find is pimpleFoam, which is essentially a PISO-SIMPLE hybrid solver, which (allegedly) is better than pisoFoam. If you still want to add the "fvOptions" feature to pisoFoam, compare the source code of the simpleFoam and/or pimpleFoam solvers in OpenFOAM 2.1 vs 2.2, to see how this feature can be added. Best regards, Bruno |
