pressure definition in OpenFOAM
Old   November 18, 2014, 10:04
Default pressure definition in OpenFOAM
vaina74 is on a distinguished road
Hi everybody, sorry for the trivial question.
I have a doubt about pressure definition in OpenFoam. I've already looked for that in the forum, but I've sometimes found different answers and samples.
If I'm right, pressure is divided by fluid density (m2/s2). Could you confirm this, please? Anyway, for incompressible solvers a relative pressure (related to a reference value) can be adopted.
vaina74 is offline   Reply With Quote
Old   November 18, 2014, 15:16
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
yes, you are correct. For the incompressible solvers (e.g. simpleFoam) pressure is actually pressure/density.
chegdan is offline   Reply With Quote
Old   November 20, 2014, 08:28
Thanks for your confirmation, Daniel. So I could define a new field for 'conventional' pressure in ParaView (filter calculator) or post-process with Function Objects. I need to investigate this, I've just had a quick look and - am I correct? - simpleFunctionObjects are not valid in OpenFoam-2.3. I'll check if swak4Foam libraries are what I'm looking for.
Old   November 20, 2014, 09:02
Daniel P. Combest
Using the ParaView calculator is easy enough, but yes you could make a function object to make pressure or even a post-processing utility to convert to the actual pressure.
Pressure farfield Boundary condition for OpenFoam mechy OpenFOAM 2 December 30, 2018 09:21
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
OpenFOAM solution is diverging for stress analysis in two-pahse microstructure. Sargam05 OpenFOAM 16 April 30, 2013 16:18
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
