November 26, 2014, 06:36 |
DynamicMesh
Cna
Rep Power: 11 |
hi foamers !
for my master thesis I want to simulate a 2D cylinder that can rotate about one axis and translate in 2 direction, this motion couse by fluid motion in other word the motion isnt known before simulation,for this I use pimpleDyMFoam in of 2.3! but becaue of large deformation of mesh the motion of cylinder cannot bacome complete and after some iteration the solution diverge I think I must utilize some feature such as add/remove layer in my case but my ploblem is when I set my case I use sixDoFRigidBodyMotionCoeffs in my dynamicMeshDict and as I know this mesh solver is fixed topology. *** can any body help me to know how I can use mesh refinement (add/remove layer) in sixdofrigidbodymotion mesh solver? thanks |
November 27, 2014, 03:34 |
#2 | |
Rep Power: 14 |
add layers, dynamicmeshdict, pimpledymfoam, sixdofrigidbodymotion |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[mesh manipulation] DynamicMesh - Move internal points | nucat | OpenFOAM Meshing & Mesh Conversion | 2 | September 6, 2014 08:54 |
Using mapFields for dynamicMesh & bad results!!! | sasanghomi | OpenFOAM | 4 | October 3, 2013 17:06 |
dynamicMesh parallel run | popcorn | OpenFOAM Running, Solving & CFD | 0 | October 2, 2012 12:34 |
dynamicMesh, dynamicFvMesh and meshPhi | mturcios777 | OpenFOAM Programming & Development | 0 | May 28, 2012 20:01 |
