wavetransmissive boundary for pressure and velocity
Dear all,
This is my first post here since I'm new to OPENFOAM (though not new to CFD). My aim is to perform a rather simple compressible simulation using rhoCentralFoam. The geometry is a simple square with zeroGradient boundaries left and right. I've added a rho*g term in the momentum equation to account for gravity. I initialize at t=0 with a pressure gradient to account for this gravity term. I would like to use wavetransmissive boundary conditions (at the top and at the bottom). Its use is described in a rather simple way in every post I've found: 0/p: top { type waveTransmissive; field p; phi phi; rho rho; psi thermo:psi_0; gamma 1.4; fieldInf 99884.8; lInf 100; value uniform 99884.8; } where lInf represents how far the boundary condition is (I'm 100% aware of how the NSCBC system of wavetransmissive works!) However, OpenFoam requires a boundary condition for U as well! This is surprising, since the NSCBC system is written in a way in which one will prescribe p only (it can be written to prescribe U also, but not both at the same time). I've tried several boundary conditions with no success: 1. calculated: this will not run (though, by the name it was my first guess) 2. pressureInletVelocity (or pressureInletOutletVelocity), which runs, but pressure oscillates without leaving the domain (this indicates that the boundary condition is reflective) 3. wavetransmissive in U: where pressure/velocity drifts away slowly from the expected value. My questions are then: What is the 'partner' boundary condition in velocity when one specifies wavetransmissive in pressure? can wavetransmissive be used with a gravity term? (I am aware that the NSCBC conditions have to compute gradients normal to the flow... this could be the reason for my problems... Many thanks for your help! Sancho |
I would say you should use also wavetransmissive for U, but you can try "advective" BC for U instead. NB: you may should use advective for other field too. regards, olivier |
Thanks for your help!
It seems indeed that the best choice would be to use the wavetransmissive BC in U as well... though this is not obvious, since a single wavetransmissive BC should set a combination of P and U, and this is enough. Having 2 of them is therefore redundant. I've had a look at the rhoCentralFoam solver, and it seems that the boundary conditions on U and on P are computed separately. This may be the reason why I have to set wavetrasmissive in both fields. Many thanks! |
what is the correct approch for using wave transmissive boundary condition in OPENFOA
do you test your case? is the best way is to apply wave transmissive for both p and u?
There is one example case in OF (reactingFoam-sandiaD). It uses 'waveTransmissive' for 'p' but 'pressureInletOutletVelocity' for 'u'. |
So it works?
However, I have come across few articles which say this may not be very well implemented in openFoam and the best is to implement NSCBC. Any leads or comments on that please? |
