Switching from simpleFoam to rhoSimpleFoam
Like Tree2Likes
  • 1 Post By mturcios777
  • 1 Post By fcollonv
Old   October 13, 2010, 03:38
Default Switching from simpleFoam to rhoSimpleFoam
Sebastian Saegeler
sebastian is on a distinguished road
Hi!
I generated a solution with simpleFoam. Now I want to have a look at the compressible case by switching to rhoSimpleFoam.
As in simpleFoam, pressure is normalized by density, I cannot use the solution of my incompressible case as a starting solution for rhoSimpleFoam straight forward. Therefore I should multiply pressure by density...
Has anybody got an idea how to use a simpleFoam generated solution as starting solution for rhoSimpleFoam?
Thanks in advance!
Sebastian
sebastian is offline   Reply With Quote
Old   October 14, 2010, 12:30
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
At first I thought foamCalc could do a multiplication, but it seems it can't.
You can modify the simpleFoam code to create a new field pComp:
In createFields.H, add the following at the end:
    volScalarField pComp
        IOobject
            "pComp",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        p*rho
NOTE: You will need to create a dimensionedScalar rho, where the value of rho is read in from the transportProperties file.
This should write out the new field at all timesteps. You'd then need to rename it "p" for when preparing the case for rhoSimpleFoam.
lpz456 likes this.
mturcios777 is offline   Reply With Quote
Old   October 15, 2010, 04:59
Sebastian Saegeler
Hi Thanks a lot!
Yes, meanwhile I did that by myself. Just a bit more simple:
    volScalarField pRho
        IOobject
            "pRho",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
        p*1.225 //p * density [kg/m^3]
    pRho.write();
Hope this may help anybody else!
Unfortunatelly it messes up a bit my boundary conditions. It even writes out the pressure field on the walls and at my pressure inlets (total pressure inlets). So I have to manually correct it at my boundaries and reset the inital settings there. Has anybody an idea to avoid that?
Best regards,
Sebastian
Old   October 15, 2010, 15:53
Arrow
Marco A. Turcios
Try creating pRho as a copy of p, then just performing the rho*p calculation over all the interior cells:
forAll(pRho.mesh().cells(),celli)
   pRho[celli]*=rho
Other than that, you'd probably have to do some switching of internal flags or something. For what you are doing, it seems like its easier just to change the BC manually or write a script that does it for you.
Old   October 16, 2010, 08:59
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by sebastian View Post
Hi!
I tried this sort of thing when I first started with OpenFOAM. I had a very basic rhoPotentialFoam solver that used the P/T values to establish a rho field and used its average value to scale the pressure etc. Note that you'll also have to scale phi too.
In the end I found that this was all a waste of time and it was much easier just to use rhoSimpleFoam directly.
olesen is offline   Reply With Quote
Old   October 16, 2010, 13:47
Default Compute static pressure during the run time
Frederic Collonval
Location: Technische Universitaet Munich - Lehrstuhl fuer Thermodynamik
fcollonv is on a distinguished road
Hi!
Thanks in advance!
Sebastian
If you know before running the case that you want the static pressure, you can computed during the run time using the function object capability of OpenFOAM.
Add the following lines at the end of the controlDict. Then a new field called pStatic = rho*p will be computed during the resolution and output in the time folders.
functions
computepStatic
type staticPressure;
functionObjectLibs ( "libutilityFunctionObjects.so" );
enabled true;
outputControl outputTime;
p    p; // Name of the kinematic pressure
rho 1.225; // Value of the density
Frederic
lpz456 likes this.
fcollonv is offline   Reply With Quote
Old   October 19, 2010, 05:49
Frederic Collonval
I just found that you can execute just the "functions" by running:
execFlowFunctionObjects
Frederic
Old   October 27, 2010, 04:54
s k
gerdahotlich is on a distinguished road
Frederic
Hi Frederic
first of all thanks for your code which works perfekt for this kind of problem.
but I encountered two problems:
1. "execFlowFunctionObjects" didnt't work for me, it actually did something (read Fields etc.), but eventually there was no pStatic. It seems that nothing happened. I just received pStatic by calculating one more step of calculation (by starting simpleFoam)
2. the BCs were messed up in pStatic, so for walls e.g. zerogradient BC in p was changed to calculated with nonuniform list. Is there a fix to that?
regards,
gerda
gerdahotlich is offline   Reply With Quote
Old   October 27, 2010, 06:58
Default execFlowFunctionObjects not so great - changeDictionary to change BC
Frederic Collonval
Hi Gerda,
I was not using that tool. But you are right nothing is written even though the function objects are executed. This is because the function "write" is not called by the tool.
It is not messed up. pStatic is computed from the field p and the density you provided. It is logical that the boundary conditions have the type "computed". The value is just the field p in the first cell multiplies by rho to obtain the static pressure.
If your plan is to switch from a incompressible solution to a compressible solution. You can correct the boundary conditions easily using changeDictionary "$FOAM_UTILITIES/preProcessing/changeDictionary". An example is explained at the begin of the code "changeDictionary.C" and an example of dictionary is provided there. But that make the trick only for the first time as define in controlDict (so startTime or latestTime).
Kindly,
Frederic
Last edited by fcollonv; October 27, 2010 at 07:00. Reason: Grammar error+add a detail
Old   July 30, 2014, 07:34
BenJ is on a distinguished road
Hi!
I've found this solution using the function staticpressure very confortable for the previous version of OpenFOAM.
But it seems this function is not available anymore in OF 2.3.0 that I wish to use now. Does anybody knows how to implement the function pressureTools (or another one ?) in order tu compute static pressure ?
Thanks in advance !
BenJ
BenJ is offline   Reply With Quote
Old   July 31, 2014, 03:08
Hi!
After reading the descritption here: http://foam.sourceforge.net/docs/cpp/a01944.html, it seems the utility has to be used as follow:
functions
computepStatic
type pressureTools;
functionObjectLibs ("libutilityFunctionObjects.so");
enabled yes;
p_k p;
rho 1.225;
calcTotal no;
calcCoeff no;
If I want to compute the static pressure, I have to set the two parameters calcTotal and calcCoeff to "no".
And indeed, when I run a case, this outputs a volScalarField "static(p)". But this one has a range between 0 and 1e-16, which does not look like a pressure in Pa.
I tried to tell OpenFOAM the static pressure p_k is p and the density value, but it does not help.
Has anybody an idea?
Best regards
BenJ
Old   January 7, 2015, 04:32
arnaud6 is on a distinguished road
Hello BenJ,
Did you make some progress with your question ?
I am facing exactly the same problem !
I can not make the computepStatic works correctly either
arnaud6 is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
TRANSONIC FLOW in RHOSIMPLEFOAM dinonettis OpenFOAM Running, Solving & CFD 10 September 13, 2018 10:22
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
Dimesion error after switching from simpleFoam to rhoSimpleFoam sebastian OpenFOAM Bugs 2 June 17, 2010 08:03
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
