July 13, 2011, 11:24 |
OpenFOAM 2.0.0 DEM method
Andrea Aprovitola
Rep Power: 16 |
Hello to the forum,
It seems that the new lagrangian functionalities included in the version 2.0.0 allow to conduct four-way coupled simulations of particle laden flows as it is reported at the following link: http://www.openfoam.com/version2.0.0/lagrangian.php
If I understand correctly the previous issues, simultaneous collisions are taken into account and there is a complete coupling with the continuos phase should mean that the effect of particle-particle interactions on the continuos phase is described by the model. Is this the right interpretation or not ? Thanks in advance, Andrea |
July 14, 2011, 09:29 |
Rep Power: 16 |
Hello Andrea!
There is a lot of new functionality for the lagrangian particles. The solver "uncoupledKinematicParcelFoam" does not include the 4-way coupling (fluid velocity field is pre-defined). We tried to do some rough comparison of new DEM functionality in OpenFOAM(R) with another open source CFD-DEM coupling for the Hopper test case. (see: www.cfdem.com CFDEM Benchmarks) Cheers, Chris |
July 14, 2011, 10:20 |
Franco Marra
Rep Power: 17 |
Hello Chris !
Nice to see you in this forum. I was just discussing with Andrea about the differences between the lagrangian library of OpenFOAM and that of CFDEM. Looking at the speedup reported in the CFDEM Benchmarks you pointed, I would ask you if the reason for the large differences can be attributed to different strategy of parallelization. OpenFOAM use essentially a domain decomposition method, for the distribution of particles too. I do not know CFDEM in the same detail (always quite low) but it should be the coupling of two codes (OpenFOAM and LIGGGTHS). Therefore, while domain decomposition should be still adopted for the fluid phase, a different approach could be adopted for the lagrangian phase, for instance a perfect distribution of particle among processors. That way, a perfect load balance could be always ensured for the lagrangian phase too. If this is the case, to increase speedup of the OpenFOAM library, a proper domain decomposition, that optimize not only the number of cells but also the number of particles attributed to each processor, should effectively improve speedup results. Your comment and suggestion will greatly help me. Best regards, Franco |
July 14, 2011, 11:11 |
Rep Power: 16 |
Hi Francesco,
As I do not know the OpenFOAM(R) implementation in detail I cannot comment on that too much... Your point is right, different domain decompositions for DEM and CFD can bring a speedup, but only when domains differ in size or particles are located in a small region of the whole domain. Which is not the case for the Hopper example. More important is probably the neighbor list build-up. (you only want to check for possible particle collisions) Another difference is the localization of the particles IMHO OpenFOAM(R) tracks them through every cell (face to face algorithm - very accurate) ,while CFDEM does lose-find which can be efficient when the coupling interval is long. Main strength of LIGGGHTS is the efficiency of its code-base (LAMMPS) and the CFDEM coupling profits from that as well. From the testcase you can see that including 4-way coupling costs time compared to pure DEM, but nevertheless it is pretty fast. I would be happy to have a more detailed comparison of the performance of the codes (what we currently have is just a rough estimate). Best regards, Chris |
July 15, 2011, 03:27 |
Hi guys,
I`m new to this forum and I`m particularly interested in DEM-CFD coupling. I ran the icoUncoupledKinematicParcelFoam case but there is no coupling happening. The solver name includes `uncoupled` which leads me to the conclusion that is not capable of solving coupled problems. Could please anybody clearify if coupling by interaction of fluid and particles (forces) is already possible in OF v2.0 or if the coupling is still work in progress ? If OFv2.0 already includes some coupling functionality what source files should I look at ? I also checked the doxygen documentation and could not find anything about icoUncoupledKinematicParcelFoam solver yet. Thanks in advance. |
July 3, 2012, 04:31 |
Creating a positioning of particles
cfd
Rep Power: 15 |
Helloo
Regarding IcoUncoupledkinematicparcelFoam Please any one how to create a positioning of particles (kinematiccloudpositions) in easier way... Regards Ravi |
March 26, 2013, 08:52 |
coupled simulation with OF2.x
Florian
Rep Power: 15 |
Hi all,
is there a possibility to simulate coupling with the continuum phase (Solver???) with the new options in OF2.x??? Similar simulations like the fluidized bed at http://www.cfdem.com/ There Should be a possibility (see here http://www.openfoam.org/version2.0.0/lagrangian.php) I tried using the icoUncoupledKinematicParcelFoam solver of the hopper tutorial. First I modified the boundary in in the blockMeshDict, to get an inlet and outlet. Then I modified /0/U with 'appropriate' values. Finally I change the kinematicCloudProperties (coupled true). However, no success. I get the following error message: Create time Create mesh for time = 0 Reading g Reading transportProperties Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model laminar Constructing kinematicCloud kinematicCloud [0] [0] [0] --> FOAM FATAL IO ERROR: [0] keyword sourceTerms is undefined in dictionary "/home/florian/OpenFOAM/florian-2.1.1/run/DEm/Test/processor0/../constant/kinematicCloudProperties::solution" [0] [0] file: /home/florian/OpenFOAM/florian-2.1.1/run/DEm/Test/processor0/../constant/kinematicCloudProperties::solution from line 20 to line 34. [0] [0] From function dictionary::subDict(const word& keyword) [0] in file [1] db/dictionary/dictionary.C at line 479. [0] FOAM parallel run exiting [0] [1] [1] --> FOAM FATAL IO ERROR: [1] keyword sourceTerms is undefined in dictionary "IOstream::solution" [1] [1] file: IOstream::solution from line 0 to line 0. [1] [1] From function dictionary::subDict(const word& keyword) [1] in file db/dictionary/dictionary.C at line 479. [1] FOAM parallel run exiting [1] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. ... With coupled false everthing works fine, but there is no interaction with the continuum phase. Any ideas??? kind regards Florian |
February 7, 2015, 10:20 |
Josefine Wilms
Rep Power: 16 |
Hi
For the particles to be coupled with the continuum phase, should there not be a volume fraction term included in the continuum velocity equation? Should the momentum equation for the continuum phase not look almost identical to that used in twoPhaseEulerFoam for the U2Eqn? I can't seem to find where the volume fraction is included in the momentum equations for any of the lagrangian solvers in OpenFOAM 2.2.1. Can anybody perhaps point out if the coupling is indeed done in the lagrangian solvers, and if it is: why is a volume fraction term not included in the momentum equation for the continuum phase? |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
