Required Fields for twoPhaseEulerFoam
Hi All,
I am new to openFOAM and I'm having trouble finding information on manipulating the constant/thermophysicalProperties file. In particular, the thermoType section. How can I find which fields are required and which ones can be omitted. I would ultimately like to model low Reynold's number blood flow, so I would like to set up the thermophysicalProperties file exclude the energy equation. Any help would be greatly appreciated! Richard |
You can find out which fields are absolutely required by the model you intend to use by:
#include "EEqns.H" You could also have a look at the tutorials and see if there is a case that uses the models you want to use. |
Thank you so much for the reply! I will give that a try.
Richard |
