k-w SST SAS for compressible solvers
Dear. Foamers.
Hi.. I am trying to use k-w SST SAS with rhoCentralFoam for compressible flows. But, I did not find out any example file for set-up. I will appreciate it if someone has an example file using SAS and share it with me. Thanks |
kOmegaSSTSAS incompressible LES turbulence
Hi eddykendo
I might be wrong but kOmegaSSTSAS is an incompressible model. Here the information from the source code: kOmegaSSTSAS LES turbulence model for incompressible flows based on: "Evaluation of the SST-SAS model: channel flow, asymmetric diffuser and axi-symmetric hill". European Conference on Computational Fluid Dynamics ECCOMAS CFD 2006. Lars Davidson The first term of the Qsas expression is corrected following: DESider A European Effort on Hybrid RANS-LES Modelling: Results of the European-Union Funded Project, 2004 - 2007 (Notes on Numerical Fluid Mechanics and Multidisciplinary Design). Chapter 2, section 8 Formulation of the Scale-Adaptive Simulation (SAS) Model during the DESIDER Project. Published in Springer-Verlag Berlin Heidelberg 2009. F. R. Menter and Y. Egorov. Cheers Fabian |
Have you managed to find any tutorials on the OpenFoam SAS model? Thanks, Tom |
